Do you have all the boot carpet pieces?
I need the left and right sides so that when I install a tower bar I can cut the extra set and not mine :P
Edited by Matvei27
PM sent
  • 4 weeks later...
Did you have pods?
I have some, but they are blue and on one side it has been hit and inverted the bottom of it. Can send pics if you want. Just PM me your number
Indicator stalk?
Sorry mate, indicator stalk is gone.
I'm keen on the brace that runs behind the glovebox. It's a metal brace that the glovebox actually bolts too. I took mine out and have misplaced it.
Hi mate, do you have the exhaust for sale? If so, what are specs? Cheers
Sorry bud, im keeping the exhaust for my build.
PM sent
hey chasing hose/connector that hooks onto aircon in engine bay and hose/connecor that leads to power steer pump.
Hey mate,
there was no aircon in the car im wrecking, and the power steering pump and lines have already been sold.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
