Do you have all the boot carpet pieces?
I need the left and right sides so that when I install a tower bar I can cut the extra set and not mine :P
Edited by Matvei27
PM sent
  • 4 weeks later...
Did you have pods?
I have some, but they are blue and on one side it has been hit and inverted the bottom of it. Can send pics if you want. Just PM me your number
Indicator stalk?
Sorry mate, indicator stalk is gone.
I'm keen on the brace that runs behind the glovebox. It's a metal brace that the glovebox actually bolts too. I took mine out and have misplaced it.
Hi mate, do you have the exhaust for sale? If so, what are specs? Cheers
Sorry bud, im keeping the exhaust for my build.
PM sent
hey chasing hose/connector that hooks onto aircon in engine bay and hose/connecor that leads to power steer pump.
Hey mate,
there was no aircon in the car im wrecking, and the power steering pump and lines have already been sold.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
