Rbdirty30 Posted July 2, 2015 Share Posted July 2, 2015 Just a suggestion on the rims as a cheap alternative, what about a 15 steel band to what ever width you desire and use a ford steel rim centre, that way you can weld the centre to band at what ever set you want. Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7561301 Share on other sites More sharing options...
2rismo Posted July 4, 2015 Author Share Posted July 4, 2015 I'm not building a race car with big heavy steel rims. Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7562099 Share on other sites More sharing options...
2rismo Posted July 15, 2015 Author Share Posted July 15, 2015 ATI Rear engine plate, crank adaptor and flex plate. Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7568061 Share on other sites More sharing options...
2rismo Posted August 23, 2015 Author Share Posted August 23, 2015 Going to need more injector than what I first thought so I've got six Precision 225s and six more Precision 550s coming for it. They hurt the back pocket but they're worth it and a proven combination with methanol. 1 Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7591954 Share on other sites More sharing options...
k_d Posted August 24, 2015 Share Posted August 24, 2015 Im assuming that measurement for the injectors is lbs not cc? This thing should be a rocketship thats for sure!!! Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7592706 Share on other sites More sharing options...
2rismo Posted August 24, 2015 Author Share Posted August 24, 2015 Im assuming that measurement for the injectors is lbs not cc? This thing should be a rocketship thats for sure!!! Haha. Yes. Otherwise it'd be about 400hp worth on methanol. 1 Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7592712 Share on other sites More sharing options...
k_d Posted August 24, 2015 Share Posted August 24, 2015 Yeah fair call. Running them staged? Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7592719 Share on other sites More sharing options...
2rismo Posted August 24, 2015 Author Share Posted August 24, 2015 Yeah fair call. Running them staged? Yep. The primaries will do everything until we need the big boys. Don't think that'll take long. Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7592724 Share on other sites More sharing options...
k_d Posted August 24, 2015 Share Posted August 24, 2015 So thats about 8200ccs per cylinder if my maths is close. Geez thats alot of fuel. Go hard or go home!!! Did i miss what size turbo your running? Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7592729 Share on other sites More sharing options...
2rismo Posted August 24, 2015 Author Share Posted August 24, 2015 So thats about 8200ccs per cylinder if my maths is close. Geez thats alot of fuel. Go hard or go home!!! Did i miss what size turbo your running? It's a Precision Gen-2 8891. Rated around about 1600hp. I'm looking for about 1200-1250 from it. If it makes anything like 1000kW I'll be rapt. Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7592735 Share on other sites More sharing options...
JAS-25T Posted August 24, 2015 Share Posted August 24, 2015 ETA on build completion? Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7592931 Share on other sites More sharing options...
2rismo Posted August 25, 2015 Author Share Posted August 25, 2015 ETA on build completion? Dunno Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7593353 Share on other sites More sharing options...
MBS206 Posted August 25, 2015 Share Posted August 25, 2015 Well make am eta up, and make it soon. Then when it goes flying past at least something will be moving quickly Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7593458 Share on other sites More sharing options...
2rismo Posted August 25, 2015 Author Share Posted August 25, 2015 That's precisely why I'm not resetting the date. This is a once in a lifetime build and it will take as long as it takes. Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7593460 Share on other sites More sharing options...
2rismo Posted September 21, 2015 Author Share Posted September 21, 2015 Ross balancer, triggers, oil pump, block-offs, brackets, drives, pulleys and more arrived today to go with the Ross billet sump pan from earlier. It all looks amazing. Can't wait to bolt it up. 1 Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7607327 Share on other sites More sharing options...
k_d Posted September 22, 2015 Share Posted September 22, 2015 Some awesome looking gear thats for sure!! Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7607838 Share on other sites More sharing options...
2rismo Posted October 4, 2015 Author Share Posted October 4, 2015 Been tinkering in the shed getting car ready for display at WTAC. 1 Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7613574 Share on other sites More sharing options...
Neil Posted October 6, 2015 Share Posted October 6, 2015 I have this 2nd hand Peterson dry sump tank of which I don't have any use for anymore if you are interested in purchasing it mate. Just needs a clean up and it's ready to go. Make a cruisey offer and it's yours mate. Sorry about the sideways pics,,,my puter is not behaving. Cheers Neil. Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7614776 Share on other sites More sharing options...
2rismo Posted October 6, 2015 Author Share Posted October 6, 2015 What size is it mate? 1.5 gallon? 2? Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7614910 Share on other sites More sharing options...
Neil Posted October 7, 2015 Share Posted October 7, 2015 Hey mate after looking at their website it looks like this one, so 3 Gals. It's a bit dirty and has the usual scratches that would polishout. The 3 straps don't have the factory bolts but thats an easy fix. 3 Gallon - 16” tall x 9” dia.08-0009 3 Gallon Single scavenge inlet, -12 AN Female Fittings.08-0010 3 Gallon Dual scavenge inlet, -12 An Female Fittings. Cheers Neil. Link to comment https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/page/8/#findComment-7615437 Share on other sites More sharing options...
