Hi SAU, my name is Aaron and I am new to the scene and to Skylines. I have come from a 2009 Mitsubishi Lancer VR:
To this! Quite an upgrade!
I picked up this maroon 1992 R32 GTR for a cheap price. It’s a bit beat up and definitely needs some fixing. Has an oil leak, cosmetically it’s a little rough, the clear coat has peeled from the wing mirrors, tail light surrounds, and rear of the side skirts, stone chips on the bonnet, side skirts are broken because it’s so low, chassis rails dented, front lip cracked and paint peeled, no air conditioning, door hinges bent, interior very average condition, two rims have buckled and all have very deep gutter rash.
Modifications that I currently know of are the Work CR Kai rims, Apexi Power FC with hand controller, R34 turbos, Trust front pipe, Jasma cannon (way too loud for me), Momo steering wheel, Tein Type HA coilovers, and an unknown but nice sounding BOV.
Going to go for the clean stock look and try to keep power as stock as possible. Except for the suspension and bracing as I am pretty keen to go to the track every now and then.
I first noticed the oil pressure was very low (almost at zero) so I went out to buy Penrite 10w-50 in an effort to reduce the leak and to raise the oil pressure. When I drained the oil it was super black and only 2.5 litres came out!! Very, very happy I decided to change it ASAP. Pressure now hovers around 4 kg/cm3 :) Also changed in a genuine Nissan oil filter, oh man that was the most annoying and painful filter change I have ever done! Which Nissan engineer thought that was a good place to put the filter?!? Have a few scars on my hand now but I heard that’s a rite of passage for GTR owners!
The steering shakes at speeds higher than 80kph due to the buckled wheels so I bought some stock R32 GTR wheels with near new tyres for a steal, and some trick chameleon lock wheel nuts. Looking pretty baller, but don’t have a proper picture of them yet. Which do you like better?
However, while changing the wheels, I noticed the coilover boots were ripped and they were leaking oil too… Time for new coils I guess! Looking at either BC Racing coils from JustJap or KW coilovers from a friend of a friend.
Once I get the new coils in I will definitely be raising the ride height and softening the dampening rate. It’s as if I am riding on rocks at the moment. Then will be taking it to Galvsport for an examination to see what I need to fix next. Was quoted $2200 for a replacement aircon compressor from Nissan! Absurd.
Stay tuned for more of Project Stock! :)
  • Like 1
https://www.sau.com.au/forums/topic/448339-slowbnrs-bnr32-project-stock/
Hahah, welcome to GTR ownership! Despite the niggles it looks like it'll be a fun project :)
  • Like 1
Thanks for the warm welcome! :)
Plan so far is to fix all of the little mechanical problems it has, and then reapply the clear coat on the tails and mirrors, get the bonnet resprayed, and generally make the car look schmick in stock form. Go to a few track days so I can feel what I need to upgrade next, then I'll look into making around 300kW!
I just ordered a set of BC Racing BR coilovers today from JustJap, can't wait!
Also, does anyone know the stock ride height for a 32R? Can't seem to find the answer after Googling...
Edited by SlowBNR
i am not sure on the health of your engine being a R32 and still using R34 Turbos (i know their BB, but still ceremic)
i just read you want to do a few track days, so unless you dont want to re-build the motor. it may be wise to do a safe tune (around 230-250 AWKW range) and GET your self a oil cooler for track days.
i would also recommond R34 dumps and pair of adjustable CAM gears before doing the tune. a nice nistune is a great options for R32's.
there is a closed FB group called - GTR's And GTR Parts For Sale , join it and have seing plenty of stuff going cheap as people upgrade.
PS - i also got BC Racing BR and love them.
  • Like 1
Welcome Aaron, car looks great!
300kw haha, I thought you were trying to keep it stock power only 2 days ago? At this rate it'll be a 'Nek minnit RB28' build :) Congrats on the purchase man
Thanks! Haha what can I say, booooooooooost is addictive!!! Especially as I've never owned a turbo car before :P I won't be looking for more power in the near future though, it's a long way off :)
I am going to get a workshop to inspect the whole car so they can tell me what else is wrong with it, but cheers for the heads up on the turbos and the safe tune, that probably sounds more realistic haha. So 32Rs don't come with an oil cooler from factory? Is the Nistune something I can just flash onto the PowerFC?
Just joined the group, super handy thanks mate!!! :D
welcome! Paint looks in good nic.
Considering its a 92 model you will pretty much have to replace the oil pump if you want to track it...
The pictures are deceiving (I think they are very, very old), there's a ton of swirl marks, scratches, few dents and clear coat peeling.
Have no fear, I will be doing all of the supporting mods before I chase any power or have too much fun with it :) Been reading up on yours too, inspiring :D
Edited by SlowBNR
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
