R32 Gtr nismo cluster $400
Hks glove box gauge holders $180
Trust drag Intercooler 100mm $700
R32 Gtr Coilovers hks drag fronts with swift springs, apexi rears with swift springs. Great condition $600
Hks triple plate clutch 90% left $1000
Apexi power Fc pro better than original power Fc suit Gtr $750
Apexi power Fc and hand controller suit Gtr $650
Apexi power Fc and hand controller suit r34 gtt neo $800
Recaro drivers seat on recaro rail suit track car $300
Recaro seats drivers and passenger on recaro rails suit skylines mint condition $1000
Garrett gt3582r turbo kit for rb25 comes with stainless manifold etc $1900
Nistune Ecu suit rb25 $400
Turbosmart Eboost 2 $400
Hks hard piping kit suit r32 Gtr $350
Trust type r bov $300
R33 gtst tein fully adjustable drift master Coilovers $700
R33 gtst Coilovers tein fronts unknown rears $450
Os giken twin plate clutch push type $700
Greddy boost gauge $70
Greddy exhaust temp gauge $70
Garrett 2860r-5 turbos with modified smaller housings for response $1100
Splitfire coilpacks rb20 rb25 rb26 $330
Blitz dual stage boost controller $180
Intercooler kit suit high mount turbo and front facing plenum comes with bov $200
Oil cooler and relocator kit $180
Brand new top speed dump pipes suit Gtr $200
Momo dished steering wheel genuine $130
Custom oil catch can removed from a 32 sits next to battery $200
R33 alloy radiator $90
Rb26 billet fuel rail $90
Bosch 040 fuel pump genuine $100
R32 Gtr tein rear Coilovers $180
Sabelt 5 point racing harness great condition $100
Walbro fuel pump in 32 gtst cradle $90
R32 Gtr custom exhaust 3.75-3.5inch with massive tuned length front pipes best sounding Gtr I've heard yet $350
Whiteline rear sway bay from a 33 gtst $100
Cusco rear camber arms for r32 Gtr gtst $130
Jdm hicas lock bar suit r32 came on a car from japan $50
Hks intake kit for Gtr elbows and filters $150
Z32 afm with plug $150 like new
Brand new omp steering wheel copy $50
Hks oil cap genuine $70
Greddy oil cap genuine $60
Nismo leather gear knob $70
R34 couple turbo back 3 inch exhaust $180
Gold Coast
0487924497 please text for pics
Hi mate, how many litres is the catch can and does it have all the fittings.
Ill take it if its 3 litres and atmosphere vented
Edited by Strick.
The HKS clutch, push or pull and does it include flywheel?
  • 3 weeks later...
Willing to ship to the US for these and cut me a deal on buying both combined?
^--- actually, I only need this. Willing to ship to the United States? You have a PM. Tried to txt your number but it wouldn't send.
I take it this guy isn't logging in to check this thread or PM? Can someone please text this guy and ask him to log in 'cause being out of the country I can't text him.
Ah, thanks for that info. If the seller isn't interested in communicating, I'm just gonna look elsewhere.
I've sent this guy 3 texts on separate occasions and numerous pm's about buying stuff. Sent him one about buying 3k worth of shit and no reply.
  • Like 1
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
