  • Replies 50
Top choice of forged pistons there Andrew. Is that the off-the-shelf RB26 CP kit, or are they customs? I went for CP customs due to 8.0 CR.
I emailed Darius @ CP Pistons at length, and he presented me with quite a few options. I couldn't believe how many different ring combinations they had available!!! Coupled with custom compression ratio, and CP Groove, and lateral gas porting, I had my hands full with choosing the right custom piston for me.
But although lateral gas porting helps achieve a greater ring seal, apparently the ports can fill up with deposits and reduce the efficiency of the porting, and are more suited for race applications where engines are pulled down and rebuilt every few races.
But the off-the-shelf piston, comes with the CP Groove, and raises compression from 8.6:1 to about 8.8:1... Coupled with decking the block/head (increasing compression slightly) and 1.2mm head gasket (lowering compression slightly), I should end up with a net compressoin ratio of about 8.9-9:1 which sounds perfect.
I'm really against dropping the compression ratio to facilitate using higher boost.
Yes I must admit I was a touch concerned about the 8.0CR. I was thinking it may result in a lag monster that needed 30psi to produce the goods, but thankfully this was far from the case.
Here's my latest dyno sheet so you can see how my engines 8.0CR, porting and turbo combo actually performs (apologies for the black and white, but I had it faxed to me) The dip up top is due to boost dropping (possible BOV leak issue?)
My combo has damn near the same response as a 9.0CR, HKS 2835R Pro S with manifold and Greddy inlet manifold (same dyno same day). It also made more power on the same boost. A few people were surprised that mine was as responsive as it is. Not only is it 8.0CR but I also run a POS old school plain bearing T3/TO4E. *Note* - the back to back comparo is not the dyno run from above.
I agree that more boost is required (1.3-1.4bar is perfect) to make the numbers on lower compression, and this in turn puts more demand on the turbo.
EDIT: Oh yeah... and I know, I need a set of cams. If someone has a spare set (or even just the exhaust), then feel free to give them to me. I say give, as $ is bloody low atm :cheers:
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
