As per title.
Complete imcludong gcg stainless dump and actuator, minus oil and water lines.
Only done approx 5000 k's street use and one dyno session.
Awesome street turbo, only removing to go bigger.
Not too sure on price, let me know if its unreasonable.
1250 bucks
On car untill Wednesday.
Ben
True!
Forgot to mention I am in fairview park sa.
Will also chuck in the flange spacer and longer studs so it will fit a stock manifold.
Removed from the car.
Will chuck in a 4 to 3inch reducer for the intake.
Will probably regret selling it as it's an awesome street setup.
Had some texts today so will paste in The highlights to save repeating myself.
The dump will bolt yo stock exhaust (but that's dumb)
I will include manifold spacer and studs and a 4 to 3inch reducer for intake
All you need to buy is a 90 degree silicon elbow (will double check size for you) oil and water lines, drain.
I had mine with all stock in engine bay pipework no worries, stock manifold
No sorry no photos of in the car. Theres photos of other guys on sau. Can take photos of dump later tonight. I know people worry about split dump cos a split dump on the nissan flange sucks, but gt30 housing s are different, if you Google it you will see what I mean, the gate is seperate already.
Powe wise depends how hard you push it amongst other things, but 300 at 18 to 20 would be possible on 98
Put it on those facebook groups, shit will sell heaps quicker.. I got rid of most of my junk in 2 weeks where it sat here for over 1 year.
Cheers man, but I don't have Facebook!
Plenty of interest but still got it. ...
Could work out a deal perhaps with brand new .82 ext gate kinugawa housing.
I'm going away for a week on Sunday, so if you want it hurry up! Or wait a week. Either way......
Remember this is the proper 3076 not the gumby smaller turbine version. I saw one of the duds on Gumtree for silly money so thought I would confirm.
Also, this is a seriously cool sounding turbo. Now that I am running a gt35 I can't belive how quiet the gt35 is. So to impress your mates with mad turbo noises, and decent power, buy this turbo!
Pretty sure I have the same turbs on my car. And yes, it sound farkin mint. Starts making a nice sound way before it starts to make power so it sounds like a large turbo spooling. Which makes all the teens at the bus stop wet.
  • Like 1
Refer to this thread for install guide. (Not mine but shows how well turbo fits etc)
http://www.sau.com.au/forums/topic/255288-garrett-gt3076-onto-rb25/
I am making 350rwhp with this turbo @ 18psi, can upload a video of boost progression & sound if you would like me to Ben?
Yeah i would appreciate it.
It is an awesome sound ;)
should keep it and put a 1.02 external rear on, probably make similar to a gt35 with awesome sounds.
Edited by AngryRB
I very seriously considered that!
Cheers for the video.
Deposit paid. Maybe the video worked?
I'd like to think if I didn't post the video, you would have taken it with you to the grave. Haha :P
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
