I had intenitons of doing a proper write up, but must have got lazy and just put the photos in that thread.
FYI, i didnt have to use the supplied washerto space the diff anywhere, I think it might be for S-chassis? Or maybe Z32. But anyway.
I find when I drive around in the wet for a little while I end up getting a fair knock in the back. It scared me a bit the first few times, but now I know what it is, I dont think about it so much lol. Would be nice to fix it, so maybe I will put the super-pro ones in one day. Want to do subframe bushes so should do it all then
So you reckon that's the rear side bushes of the diff? Sounds odd, especially if it's only in the wet.
Is anyone else running the Nolathane/Whiteline diff bushes, how are yours going?
Only because they used to be press fit bushes. The front diff mounts I have are whiteline ones but they are a similar design to the standard ones anyway.
Im relatively sure its the rear bushes. Its not a big issue. The noise goes away when it all dries up. But it does annoy me a little
Diff is back in with SPF bushes in front and Nolathane in the rear. I am not super impressed with the Nolathane ones either, they don't feel super tight and the diff sits a bit further back that with the OEM ones. I tried with the spacers too but it wouldn't tighten up properly. Very easy to install though obviously and at least the bolt hole is the right size unlike the SPFs...
I'll let you know how if feels once I've got the rear back together, need to slap the suspension and HICAS delete in there.
HICAS Eliminator kit and suspension are in, just needs rear seats and exhaust back in now. Although I might get my brakes tomorrow so will leave it on the stands for a bit longer ;)
I thought you didnt want to wait for replacement rear bushes from super pro?
Good point - I haven't even raised it with the supplier as yet. From previous experience warranty claims take ages so I've gone Nolathane for the bushes for now. Brakes didn't arrive either (sad face) so I'll put it all together tomorrow, at least I will have a car that is drivable... will be nice to get some groceries after two weeks :)
The car is back together since last night and the clunk from the diff is gone. The HICAS delete feels fine too, however it will need a proper alignment soon of course.
I wasn't happy with how the diff sat with or without the supplied 7mm spacers so I ended up putting a standard 2.5mm washer in there that seems to work well. I'll post photos of the whole project at a later date.
Thanks heaps for your input everyone, especially 89CAL and GTSBoy, extremely helpful!!
Can you do me a favour? Just spray underneath the car with some water (fair bit) and then go for a drive, mine usually clunks when taking off from a standstill
Interested to see if the washers have helped, I didn't bother fitting the suplied spacer because it was no good at all, but might fit a standard washer as you've done if you dont have any issues with clunks etc.
Yeah man I'll check this once the car is a bit dirtier just washed it after a couple of weeks :)
Did you grease the bushes before putting them in? I wonder if that could cause noise.
Also out of curiosity, when you did yours, did you disconnect drive shafts at all or just drop the diff a bit?
I used the supplied grease with mine. I think (but it was a while ago) I installed them dry, then noticed the noise and thought I would try with the grease, but didn't really make a difference.
I think I was going to remove the diff completely till I realised I'd have to remove the rear of the exhaust and Couldnt be bothered getting gaskets (even though in hindsight that would have been easy lol) so I probably removed the driveshafts off the diff and hung the diff down.
Yanack Racing make unreal diff bushes.
I have these for the S15. Quality is high end & they're chromoly. Made in Japan
Thanks, that's interesting, I found some at RHDJapan: http://www.rhdjapan.com/yanack-diff-mount-rigid-collar-set-rear-nissan-s14-s15-r33-r34-c34-c35.html
Based on the pics they're solid metal, a bit like these GKTech items: http://www.gktech.com/index.php/s14-s15-solid-diff-bushes.html
Probably good for track/drift but not sure if I'd want to run solid bushes in a road car, experiences anyone?
I drove to work in torrential rain this morning, like most of Melbourne it seemed. I can't really point to any difference in noise/clunks/performance between dry and wet.
I'm not overly convinced that the problem you're having is directly related to the diff bushes, however can't think of an alternative cause either... Hope you get it sorted.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
