I am looking for EOI for my 1992 Nissan Skyline GTS-t. I bought the car a while ago after owning an MX5 and am only selling as I regret getting rid of the MX5. The car is in a very clean state, especially when comparing to other ones. I have receipts for it dating all the way back to 2010 and I have kept every receipt for it since I purchased
159,000km
Manual
RB20DET
Rego runs out next month but will slap on another 6 months for buyer
$9,000
The car has the following modifications done to it:
- Power FC
- RB25 Turbo with 360 degree thrust bearing
- Splitfire Coilpacks
- 550cc Deatschwerks Injectors
- Stainless Braided Oil Water and Break Lines with Speed Flow fittings
- Front mount Intercooler
- HKS Turbo Timer
- Auto Meter Boost Gauge
- Cusco Strut Braces front and rear
- AVS Model 6 wheels (17x8+35)
- HSD Coilovers all round
- ARP Headstuds
- Cometic Headgasket
- HICAS Elimination kit installed by Option1Garage
- Front and Rear Camber arms installed by Option1Garage
- Mongoose Alarm
- Headunit with AUX
- Nismo Thermostat and New housing
As you can see quite a lot of money spent on the car and no shortcuts taken. The car is currently my daily and has a tune for waste-gate pressure (8psi) but all the mods are there to easily make more power reliably.
The downsides of the car is that the C-pillar lining's are missing (were taken out to do work but one was lost and the other broken) and needs new rear window tint (bubbled up due to age). Also the gearbox makes a whining noise but has done so for 10,000km and still works and feels fine.
Always run on 98 Octane fuel, Dash has NO bubbles, Vents aren't broken like in every other R32
Apart from those issues The car has been absolutely fine and have enjoyed driving it every bit. I am in no rush to sell it so I am only slightly negotiable. it is truely one of the cleanest R32's i've seen and was the only reason I purchased the vehicle in the first place and I would not even think of selling it if I didn't miss my MX5 so much.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
