Exactly. Why is this a thread?
Cos people like to start threads that are either easily answered or already answered.
Or spend ages writing stuff only to eventually actually look at the car and find a blown fuse or popped hose in 40 seconds.
  • Like 1
i was after YOUR opinions though when i mention it failing
i guess everyones opinions turned biased now lol
that wasnt the point though, was curious which guideline it fails under though that has been answered by jiffo :closedeyes:
Edited by KrazyTurk
I don't have a license to do roadworthy's but I've driven cars before and it looks fine to me. I think you should go back to him and let him know you have asked other people who haven't actually seen the car and been told it's ok and they should either pass it, or give you your money back on the RWC. You could also try the ol' "it's a factory option" line, but I don't know if it will work in this case...
  • Like 1
Rust.
Time for a paint job, cos you will have to cut it out and weld a new piece in there.
You can cut a bit off a wreck or have it made by a panel beater.
Youtube will teach you how to do it.
Lots of good tutorials there.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
