Voltage to the ECU seems to be fine and I've connected the multimeter to the negative terminal and my earthing points on top of the rocker cover. Seems like the resistance is ok. I didn't expect there to be grounding issues as the wiring is very neat and tidy.
I may have found the problem though; turning the screw on the AAC isn't actually doing anything other than making idle leaner. I was expecting that turning it counter clockwise would cause the idle rpm to rise but it's not doing that at all. I would assume that this would affect both idle and the air con system.
I'll take a picture of that and post it if that can help confirm? It's definitely going lean if I turn the screw anti-clockwise and not increasing the idle speed but there doesn't seem to be any additional piping down there.
There's no vacuum leaks in the system either though as I had a smoke test run which held pressure very well indeed.
You need to disconnect either TPS or one of the plugs at the AAC to adjust it cant remember which one
disconnect IACV & the TPS
The AAC is purely for warm up (from what I see) and is not adjustable.
Hey guys,
Sorry for the delay in replying, I've actually been off on business and had to drop the car back in the garage. I've ordered the AAC gasket so I'm going to take that off and give it a good clean when I'm back but it won't be for a good week or so. I have a feeling that my AC issues/dodgy idle when cold is probably down to something around here as the electrics seem fine.
I wonder if someone could clarify for me though: -
http://img.photobucket.com/albums/v150/tegguy/002.jpg
Is this the IACV? I thought that this was the cold air control valve - can this be taken apart and cleaned easily?
http://i217.photobucket.com/albums/cc252/kagekispirit/TechNical%20Support/Rb26AACvalve.jpg
This is the AAC and the part I just bought the gasket for and is the component that has the screw on it. I'm going to take this off and clean with carb cleaner until it shines! :)
First photo is called the Air Regulator by Nissan.
It's simply a cold start/fast idle 12V bi-metallic strip valve which allows idle air to by-pass the throttle plate and flow directly to the plenum, thus increasing idle speed.
Engine bay heat will eventually close the valve irrespective of the 12V supply.
It's one bit of gear I always block on my Rb's as I find the AAC can do everything I need.
If you trace your idle air pipe work, you'll find a tee where the idle circuit splits with one circuit running to the AAC and the other circuit running under the plenum to the Air Reg. (brown plug)
Your car also has the idle bump up activated by the aircon.
A simple solenoid valve by-passing the AAC and allowing idle air directly to the plenum, thus increasing idle speed. (The solenoid with the purple plug)
Thanks for that! So I am going to be cleaning both of those and checking the pipe work for problems. I'll also do an idle re-learn on the power fc.
As far as unplugging the purple wire, I felt a little uneasy about that as I couldn't see why cutting out the air regulator would be a good idea. I can't see why nissan would put a part in whose problem can be solved by unplugging it lol. I guess I will have a go, I'm just not overly confident that I know what I'm doing so I don't want to be driving the car around with wires unplugged.
Regarding the screw on the second image, I.e. The one I thought was the AAC, which has the AAC sticker on it, is it the TPS wire that I need to disconnect? I've read so many posts that say that it's the brown plug, some people saying the TPS etc, is there a definite answer for this on the rb26? I expected that if i turn the screw the idle speed will change, but when I was doing this, I had disconnected nothing.
I see, well I can get at them, I've got the tools to take them off and I'm hoping that cleaning it out may help the air con problem and the idle issues.
Do you know if it is the brown plug or the TPS that needs disconnecting to adjust the idle rpm screw?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
