There's a table that lists the temp and the enrichment in both negative and positive.
When the charged air is more cold more fuel required as the air is more dense. Without adding more fuel your combustion will burn leaner and reverse goes for warmer air, it's less dense so you need less fuel.
Very crucial sensor for a MAP car
Install it after your FMIC however don't install it in the engine bay as it will heat soak.
On the ECU you will need to run a wire from pin 36 to the sensor and another wire from pin 30 (sensor ground) to the intake air temp sensor. Do not ground it off on the chasis, it will read wrong.
Series 2 ECU will have something connected to pin 36 but just chop it. I believe it's the TPS close position which is useless. On a RB26DETT harness it's used also as the IAT
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
