There never was a stock 300GT manual, so hard to say how well it will drive.
Given that.. I think that is a cheap price, make sure you get it in writing that this is a complete 'turn key' job and they will resolve any issues it creates. As it is unlikely anyone has done this before, so there is likely to be several 'unknowns' along the way.
My guess is that figure is for the mechanical work alone..
Thanks for the replies. Its my first auto car. My previous was a renaultsport clio which was very entertaining. Im finding the 300gt a little boring by comparison. After the responses and talking to a couple people I think I might just leave it as is until I can get something better. Lesson learned. Dont buy autos
Yeah you will need the interior trim too and some form of electronics to run it? Because the standard ecu is for an automatic.
FWIW in my R34 the auto ECU runs fine with the manual box, even the Nistune works fine. Your mileage may vary.
I know electrical will be annoying. What benefits is there of going manual. Is will still be a gutless 30dd
Cos manual = more fun?
Indeed manual does = more fun. Shame there is f all manual sedans around.
There are a few.. when I bought mine, there was 2 others on carsales. But at the moment, it seems the only 350GT sedan on there is a CVT.
Don't say that... Whilst a manual 350GT (for example) may be more 'fun'... I enjoy my 5 speed sports auto far more... torque torque torque and very responsive... + the manual mode is good fun if you want to hold gears :)
Have you considered selling your 300GT and using the money that you would have outlayed (eg: $3000+) towards a 350GT Coupe?
Edited by Sikahalv
I would just hang out until a 4dr manual appears for sale. Too many unknown 'gotchas' with converting a 300GT to a manual, unless you know someone who has done it before. You could possibly need a whole aftermarket ECU to make it work properly..
I decided to not go ahead with the conversion. As much as I would prefer a manual I may look into a v36 sedan with the better engine and hopefully better auto. If the 5 or 7 speed auto is greatly improved over the 300gt then I could forgo a manual I a suppose. Anyone gone from the old v35 auto to the newer? And are they that much more responsive?
I Drove a V36 sedan, 350 GT, 5 speed auto. I was keen to buy, but the dealer could not supply the de-reg papers from Japan. Despite having a 235kw engine I did notice any major performance increase over the V35 coupes. I think it may be on account of it being heavier, and apparently they have less torque.
It was a nice car, but there was a bit of lag from the paddleshifters when changing gears.
I settled on a V35 coupe (we have a 7 seater Dualis for my wife/kids anyway) and don't regret a thing. Without a doubt, the best car I have ever owned.
I thought the VQ35HR had the same torque figure? It recovered the torque the DE revup engine lost and increased power further.
And it was 230kw in the V36.
Edited by sonicii
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
