Gary's pricing is still not bad, and you do get the custom valving and extra circlip grooves that you wouldn't get buying the Bilsteins vanilla from eBay.
true that, I don't have the circlip grooves on mine...
will be offlloading my set in a few months.. they're great on the street, but not that great on the track unfortunately...
Will be moving onto MCAs coilovers :D
Let me know when you plan to get rid of them and how much. I plan to get rid of my coilovers. Too hard for my liking. Do you have good ground clearance?
sure thing :)
You've seen my car (I think).. it's not that low. The rears have about a 2cm gap to the guard and the fronts about 3cm.
The Bilstein pbf cattle dog has the following listed:
NISSAN SKYLINE Coupe (R32)
2.0 4x4, 2.0 Turbo 4x4, 2.6 Twin Turbo 4x4
B6 Sport
Front 24-014717
Rear 24-014724
B8
Front 24-016728
Rear 24-016735
My shocks have the following on the stickers:
Front F4-B46-1471-HO
Rears F4-B46-1742-HO
Most people have the B6's but am not sure what the B8's bring to the party. Says they are a shortened version which would be useful at the front, not so much the back. Don't know what the valving differences are, however.
Edited by djr81
B6 (which is the B46 part number) are great shocks. B8 are the next step up in quality. Hard to say how much better they could be than the B6s, seeing as the B6s feel so nice and work so well. But Bilstein aren't in the habit of telling us lies, so they must have something over them. I agonised a bit over the choice - read the Bilstein website a fair bit, and decided to save the money involved iin stepping up to B8.
recommended spring rate for mostly street use with spirited driving on backroads?
I have R32 GTSt, so my comments are kinda relevant to GTR, but with some limitations. So read this with at least one squinted eye.
Stock GTSt spring rates are <3kg/mm. The Kings low and the Whiteline spring that Gary recommends for GTSt with his Bilsteins are about 4kg/mm. I tried these and for whatever reason they simply don't work. They were far too low and could not be set up high enough. So I ended up with the Kings lows for GTRs. These are >5 kg/mm. They are quite firm, but the Bilsteins give great control.
I would expect that they would still be great on GTR, even with the extra weight.
I have posted fairly extensively on this experience some months back, so search up those posts for more accurate numbers and my sad but happy ending story.
It depends. The biggest problem is getting a decent amount of travel t the front. I would recommend Eibach 65 dia springs, 5/5.5/6 kg/mm front and depending on your preference probably a kg/mm softer at the rear. Use 10" spring if at all possible and make sure you get some strut tops as without them the suspension travel is hopeless.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
