hey all any ideas.
bought a rb20det..opened it up and found little marks where the valves have just touched the clearance cut outs in all pistons in and ex.about 2 mm near the 1/3 circle valve clearance cut outs.each one has about 3 little hits not very deep.its had adj inlet cam gear set on 0,arp headstuds and a 1.3 mls gasket.valves on head have no marks.this is probably why it had 05 pistons put in and the head recoed at one stage.i want to install hks 264 9.1mm cams and heavy valve springs but I want to know how could these marks have happened.do I need to put a thicker headgasket..is this usually a problem.cheers
https://www.sau.com.au/forums/topic/449885-rb20det-valves-hit-piston-marks/
Nope.someone please get a f cking spoon out for me please. I tried for 1 1/2 hours last night still couldn't upload a photo.Yep I know instructions have been sent to me.and also no luck searching on google how to do it.i tried looking for a "direct image link function" button. so in imjur there is a column on the right with all the http locations when I get my photo up and when I click on the little icon on the left hand side it says copied.how do I get it to my post.On my post I tried clicking on the paste buttons = no good.i tried to drag it from injur to sau but it doesn't work. I need a spoon. I don't want to read another ten posts of negative crap of how ive been instructed. ive tried and I just cant seem to get it to work.i appreciate the positive help.i just want to get a picture of this bloody piston up.Oh I also tried clicking on the actual pic to copy...nope no luck......
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
