Feedback:
I made a suggestion a while ago about the "/Events" area having heaps of threads from last century and an "/Events Archive" was created, great fantastic!!
The problem is their is currently over 220 threads in the "/Events" section when their should only be around 20 (the other 200+ are all from earlier this year). It makes it quite time consuming and hard to work out what events are actually on soon and what was on 2mths ago when you have you go into each thread etc etc.
I think more people would attend these posted events if it was easier to navigate by having ONLY the future "/Event" threads actually listed and the rest thrown into the "/Events Archive" basically, it's not being looked after.
I'm happy to volunteer my time (for the NSW Section atleast). Gotta do something to keep me occupied when doing those niteshifts at work :(
and I just checked it and there are 6 events in there at the moment, the rest are in event archive, it's been like that for a few days now
I can see 180 threads (including sticky's). Can't be 180 future events over the next few months posted is their ? Most of them are from 2003 :(:)
Well how about that, never noticed those bottom settings before :(
Guess you learn something everyday and here it is only 1:30am :rofl:
I still think the threads should be moved as soon as they are "past" tho :) Or maybe rename it to /Future Events + /Past Events etc so that as soon as an Event is over (eg: Putty Rd) the discussion continues on in the /Past Events area :rofl:
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
