Item for sale: custom built 1pc tail shaft by Universal Drive Shaft Services.
Contact: Tim 0410 544 487
Price: $600ono
Looking for a new home for this tail shaft that came in a car I've bought recently, someone who can make use of it as it is overkill for my intentions. I've put a stock tail shaft in my car.
This will make an excellent addition to some one with a manual coupe, non abs who is chasing big power.
As you'll see in the photos, it's still in as new condition and was very costly to make.
I am open to offers and swaps for clean GTR seats.
txt me anytime.
Thanks.
https://www.sau.com.au/forums/topic/450279-fs-bris-r33-1pc-tail-shaft/
The tail shaft is of excellent build quality, I can't imagine it ever having a reliability issue. The previous owner of the car had big HP plans for the car which never came about, being the reason for this tail shaft and the ridiculous clutch that I'm also about to take out of it.
There is nothing wrong with these parts I'm removing, just that they are too much for the car as I want it.
As for vibrations, at first I thought this tail shaft was the cause of a vibration the car has but since changing the diff and tail shaft back to stock items, the vibration is still there. So, I can't fault either of those items for causing a vibration as it's still there. I'm now thinking it might be in the rear wheels or something else like that.
I will get some proper measurements tonight but from memory length is a bit shy of 1400mm overall, width would be a bit shy of 90mm and weight would be about 8kg at a guess just from carrying it on the weekend.
My post code is 4053 at home or 4009 at work, can get it picked up from either. Or I can drop it at Pack&Send Brisbane CBD, I called them today and they said roughly $82 to send to Sydney fully insured and tracked, I took a guess on the weight when I spoke to them though.
I have had someone make an offer via PM but have not got back to me to confirm yet.
Hey guys, tail shaft is still available, although there has been some interest, just waiting for someone to pull the trigger.
In addition to this I now also want to sell the clutch that just came out of the car.
I must warn though, as you will see in the photos, this clutch is not very suited to daily drivers.
It was removed from my car as I'll never make enough hp to need it and I'm driving my skyline daily a at the moment.
Only a few months old and hasn't done many k's, just like the tail shaft.
Looking for $1250ono.
No worries, the clutch is much better suited to your car, will be good to see it all back together and racing.
I currently have a $300 offer on the tail shaft, is anyone willing to pay more than that? $400 maybe?
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
