Hi, i have recently installed a 5 stud conversion on my r32. I am at the stage where i cannot seem to get the rear brakes to clamp the rotor!
all the gear off a r32 gtst including
-brake booster
-bm44 MC-
-4 pot 5 stir up front
-2 pot 5 stud down rear
I have alson installed some g tech brake lines.
After bench bleeding the MC for all extraction of air, all outlets flowed nicely.
Installing the MC onto the booster and connecting the brake hard lines i then start form the rear passenger brake.
Using the 2 man bleeding method (open bleeder, brake pedal down. Close bleeder brake pedal up) and repeating this method until a clear, air free stream. Going around all 4 callipers at least 5 times.
After this the pedal feel was completely soft 2 thirds (2/3) of the way down then you would hear a clonck and symoltaniously the pedal will become hard. This also happens when the rear calliper bleeder is open, opposed to when bleed ing the front calliper when the bleeder is open the pedal goes str8 to the floor.
After taking it up the street I found out only the front brakes were working. (when the car is on the same pedal feel present 2/3's down nothing then the front brakes engage).
After being thoroughly confused i took the calliper off the knuckle and getting some one to depress the pedal i saw the brake pads close after the 2nd or third press of the pedal, Which i would presume after the 1st pump making pressure then the brake pads would move, so I'm thinking this eliminates the calliper being seized. So it must mean there is air somewhere in the system.
So here are my questions.
WTF is going on???
Could there be air trapped somewhere in the callipers? or the hard lines?
Is the MC f**ked?
How man bleeds or amount of brake does it take to completely get all the air out and get a nice pedal feel?
HELP please,
Seems like you do indeed have air in the brake likes that run to the rear, when you changed the MC air tends to get into the steel pipe that goes into the MC and will take quite a bit to move all that trapped air all the way down the lines into the caliber and out the bleeder, I would suggest to re bleed the rear brakes some more and see if it comes good
You didn't inadvertently install the calipers upside down did you? As in, fitting the left side caliper to the right and the right side caliper to the left. This would put the bleed nipple at the bottom of the caliper instead of at the top. And make it impossible to get all the air out of the system. It's an easy enough mistake to make.
  • Like 3
You legend! the nipples are at the bottom right now, i will flip them, bleed them again and let you know. Giving that you said it is a simple mistake to make that sounds very much like a thing that i would do and have done.
Glad I could help.
Don't worry, I've had several cars come in to the workshop with the same issue. Always after the owner had worked on the car themselves, but even by some pretty mechanically minded guys. So like I said, it's a slight oversight. Swap the calipers around and it'll be good to go.
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
