Hello fellow car people! I'm going to collect my first RB26DETT engine on saturday to start my BMW E30M3 NIS///MO project.
The last couple of weeks I have spent hours on hours reading about the engine and what I should take care of first.
To get you up to date I use my car as a sunday car, but I want it to perform well on the track. I don't attend any competitions, I just fancy driving as fast laps as possible. The car it setup with very expencive suspension and brake parts etc. My aim is reliable 400-450hp without doing too much modificaton this winter. What I want to do how ever is to get the oil breating and lubrication sortet first thing first. That include stripping the engine I guess.
I have spent some time in the oil control thread, and have got some of a clue on what is going on. The list that I have come up with on the top of my head I will give you a write up on. I want to install the engine and do all the wiring and hardware work before taking it out again and do the oil job.
So, I have gotten my hands on a 110.000km R32 GTR engine that is late model with pull clutch. This is beeing matet with a R33 GTS-T 5 speed gearbox and converted to push type clutch. This is beeing done by the shop that I'm buying the engine from. Engine is complete swap except AFM's.
So, the list will be:
-N1 oil pump with billett gear
-1mm restrictors (mainly street, but hard when it is on track) Two pcs pr engine?
-2l oil catch tank with two plugs for each rocker cover and two for the sump with filters on top
-Mines or equal rocker cover baffles
-Tomei oilpan baffle kit
-10mm drilling of the oil returns (is that in the block or head? Both?)
-Nitto crank collar
-Fluiddampr
I see it is recommended to expand the sump. If I'm not wrong the sump will be pretty low in the E30, so if I'm going to expand the sump it will need to be to the right or the left. My plan is to use the GTR sump, but remove the excess frontwheel drive stuff that it has on it and plug the holes for the driveshafts.
As far as hp gaining is, I'm building my own 3" exhaust, using stock turbos at first, intercooler will be about the same size as stock Skyline, probably need to make my own suction kit and turbo elbows. What do I need to do with the ECU? Do I need bigger injectors? Adjustable fuelpressure regulator?
So, it anyone have som input to a noob on RB's it would be nice. Or am I totally baked here?
Cheers from Norway!
https://www.sau.com.au/forums/topic/450443-newbie-r32-gtr-engine-upgrades-etc/
I have checked out the N1, the R34's and the Kinugawa TD05H-16G and the TD06SL2-20G, don't know the difference on the latter two.
The TOMEI Arms kit does not fit into the budget. MIght get the Tomei headers though.
There is already a Bosch 044 in line fuel pump in the car by the way.
Edited by SSM
if you hve the motor out i'd be doing the turbo's before putting it in....they are known for spitting the ceramic exhaust wheels down the exhaust pipe.
thats my 2 cents.
I can vouch for this.
If you are going to spend all that kesh on the car. Get new turbos. -7's, -5's, -9's
i can pretty much guarantee you will spit a turbo wheel
i unno crank HP
Mine currently make 320AWKW on 98
In getting E85 so who knows what ill make then. 340-350 around there i think. Maybe higher. Can't find much info on them for E85
I made 313rwkw @ 19psi on my -7s, personally I would look at the TD05-16g
3.5" exhaust aswell
If the motor has a pull clutch then chances are it also has the wider oil drive so no need for the Nitto one, but check it while it's apart
The RB26 only has one oil feed for the head, the rear one is blocked usually, again you won't know for sure till head is off, either way fit the 2 x 1mm restrictors even if it means removing the bung from the back one
An RB30 sump will bolt up to the RB26 block
If you don't plan on running more then 15psi and aren't planning on covering the car in tyre smoke the stock turbos will last a while
yeah man i love my -7's.
Drop straight in too :cheers:
i can't see an answer to your ECU question. Depends on what you want to spend. Apexi PFC will do what you want, you can pick them up for around $600
Or do it properly and buy a haltech for future proof. I'm going through the process of removing my PFC for a haltech currently. Haltech is around $2000
i would get it in a running before f**king with it
stock motor is going to be awesome in a e30
once its running perfect and you have ironed out all the bugs then modify
Yes, that is my plan as well.
The stock motor will be slower then the one I had. That was a 236kw/350nm NA engine.
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
