with the new rules that came out with the vsccs system your limited to same make for engine swaps now, so no 1jz skylines without a engineers report now :( its on the updated vsi06
I meant, e.g. Carbie 304. So efi blocks with carbie induction on certain year cars. And also that there was a limited run of VL's that came with a carbied 308 and 304, I had no idea until I called my old blue slipper
Don't bother calling the government or the rta etc as they have zero idea on anything. I actually had a guy telling me it was illegal and asking for the rego.
Call a blue slipper and they will be able to tell you straight away whether it's legal or not.
Edited by Stagea97
yeah i know about those things, i thought you ment swapping parts between makes, im auvis (blueslip) at my workshop, the vsi 06 has the basic rundown though, the RVDs also show what came out optioned on what car.
http://myrta.com/rvd/searchRVD.do
Edited by Scott Black
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
