I want to strengthen some of my tranny component and I'm looking for feedback or opinion on this.
1) Anyone tried one of these process ? should I only do one process or can I do 2 or 3 of them ?
2) which part should I think about treating ? gear + synchro ? Anything else ? Should I try to treat other component of my engine rebuild ( valve- valve spring - camshaft - piston etc.)
Thanks guy :)
  • 1 month later...
Shot peening and cryo seemed to help on a diff. Never tried WPC
Some gearsets come peened and cryo from factory, i.e albins
Also heat can make shit expand, a pinion heated up to 80 deg c gained 2mm in length which changes
the contact patch, if your running on the brink of failure for 20+ mins in competition you want to
look into additional capacity, additional fins or even pumps and coolers
Wouldn't bother doing it to an aftermarket gearset, most are peened already if helical.
valve springs are already peened, would not bother cryo
Would not bother with cam either, snapping cams you have other issues
I have cryo'd a crank before, but that was when it was new and still cheap.
Closer to .02mm
Given that steel has a thermal coefficient of expansion of about 12x10-6 m/m K, a 50mm diameter pinion will grow approximately 0.033mm when heated from 25 deg C to 80 deg C.
On the heavy mining equipment we run the gearboxes with .5mm to 1.5mm backlash, and those pinions are about 300mm diameter, with gears about 1.5m diameter. The change in backlash is negligible when they are at full operating temperature. Scaling that down to an automotive gearbox running 0.1 - 0.2mm (?) backlash, I would think that any expansion beyond 0.1mm (combined between the pinion and gear) would be catastrophic.
Nope, it was 2mm, pinion in particular was from a Subaru front. It is very long
and part of the layshaft so box temp is the same as front diff. An R200 is about
half the length.
Peened, cryo, backlash set for higher temps, gearbox oil cooler and pump
solved the problem
  • 2 months later...
Yep. True story.
Altho that clutch also saw off a couple OS gear sets too. I think someone needs to try it with a friendlier clutch, for a better test.
But my gearbox guy cryo's high hp 4WD autos with really good results also. ?!?!
Autos force shock impact will always be less than that of a manuals shock impact.
Many are Cryo treating Auto parts with great sucess, manuals are more a mixed bag of results with more manual components failing.
Those breaking manual boxes and drivelines on launch (only) have learnt that loading up the driveline with some clutch grab to take up the driveline slack before launching violently have had reduced breakages just by changing to that technique.
Most breakages are from sudden shock impact loading.
tric - any oiling mods in your gearboxes? I hear that Award Diff and Gearbox here in Sydney do *something*. Might also be worth trying something like Liqui Moly Mos2 gear oil additive as a hack as it should help if there's any starvation causing the gears to fall out of sliding hydrodynamic into boundary lubrication.
Edit: are your failures as you just start to gun it in the gear, or after you've been gunning it in the gear for a while?
Thanks Stabby. I have since sold the GTR with a new OS box and coppermix clutch. I did put a lot of the breakages down to brutal R3C OS clutch. Most breakages were on the shift or just after. And quite a few were towards the end of track work or sprints so I definately think a cooler would help. But this is all getting a bit off topic, so I still couldn't definitively rule out Cryo being an option with a nice sprung centre clutch.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
