I want to strengthen some of my tranny component and I'm looking for feedback or opinion on this.
1) Anyone tried one of these process ? should I only do one process or can I do 2 or 3 of them ?
2) which part should I think about treating ? gear + synchro ? Anything else ? Should I try to treat other component of my engine rebuild ( valve- valve spring - camshaft - piston etc.)
Thanks guy :)
  • 1 month later...
Shot peening and cryo seemed to help on a diff. Never tried WPC
Some gearsets come peened and cryo from factory, i.e albins
Also heat can make shit expand, a pinion heated up to 80 deg c gained 2mm in length which changes
the contact patch, if your running on the brink of failure for 20+ mins in competition you want to
look into additional capacity, additional fins or even pumps and coolers
Wouldn't bother doing it to an aftermarket gearset, most are peened already if helical.
valve springs are already peened, would not bother cryo
Would not bother with cam either, snapping cams you have other issues
I have cryo'd a crank before, but that was when it was new and still cheap.
Closer to .02mm
Given that steel has a thermal coefficient of expansion of about 12x10-6 m/m K, a 50mm diameter pinion will grow approximately 0.033mm when heated from 25 deg C to 80 deg C.
On the heavy mining equipment we run the gearboxes with .5mm to 1.5mm backlash, and those pinions are about 300mm diameter, with gears about 1.5m diameter. The change in backlash is negligible when they are at full operating temperature. Scaling that down to an automotive gearbox running 0.1 - 0.2mm (?) backlash, I would think that any expansion beyond 0.1mm (combined between the pinion and gear) would be catastrophic.
Nope, it was 2mm, pinion in particular was from a Subaru front. It is very long
and part of the layshaft so box temp is the same as front diff. An R200 is about
half the length.
Peened, cryo, backlash set for higher temps, gearbox oil cooler and pump
solved the problem
  • 2 months later...
Yep. True story.
Altho that clutch also saw off a couple OS gear sets too. I think someone needs to try it with a friendlier clutch, for a better test.
But my gearbox guy cryo's high hp 4WD autos with really good results also. ?!?!
Autos force shock impact will always be less than that of a manuals shock impact.
Many are Cryo treating Auto parts with great sucess, manuals are more a mixed bag of results with more manual components failing.
Those breaking manual boxes and drivelines on launch (only) have learnt that loading up the driveline with some clutch grab to take up the driveline slack before launching violently have had reduced breakages just by changing to that technique.
Most breakages are from sudden shock impact loading.
tric - any oiling mods in your gearboxes? I hear that Award Diff and Gearbox here in Sydney do *something*. Might also be worth trying something like Liqui Moly Mos2 gear oil additive as a hack as it should help if there's any starvation causing the gears to fall out of sliding hydrodynamic into boundary lubrication.
Edit: are your failures as you just start to gun it in the gear, or after you've been gunning it in the gear for a while?
Thanks Stabby. I have since sold the GTR with a new OS box and coppermix clutch. I did put a lot of the breakages down to brutal R3C OS clutch. Most breakages were on the shift or just after. And quite a few were towards the end of track work or sprints so I definately think a cooler would help. But this is all getting a bit off topic, so I still couldn't definitively rule out Cryo being an option with a nice sprung centre clutch.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
