sO ch10 couldnt turn a dime with coverage. i am paying $20 for internet access. $50 for Foxtel Play just to watch tonights race in a hotel! Farking better be a good race!
Cracking good race. Best one I can remember for years. Good to see Williams up there running one two - just all turned to custard when they lost grip levels, their aero appears not to enjoy slower speeds.
So, who to Williams after Bottas goes to Ferrari to replace Kimi? Hulkenberg?????
Well not sure whos engine supply they are taking over?
Lotus? Force India? Williams?
Plus it will obviously be at the cost of the Infiniti sponsorship. Cant imagine Aston Martin has that much money to throw away on sponsorship anyway.
Do I believe it? Not more than the Ferrari engine stories.
Williams are rather sgit at strategy. Lotus in 2013 got it right with Romain...give yourself track positiin and stay in the fight as long as possible. They were 1-2 and simply got stage fright...no matter what Smedley says.
Rain came and mattered for 0 anyway.
Meanwhile Dan sucked...Lotus sucked....but finished MWs book and wasnt a bad read
There was talk of links of Flav to Aston but wont happen. I love how Pat is a clean skin yet Flav is tarnished by Singapore events...even though cleared by FIA of having knowledge...unlike Pat.
Really hope Bottas doesnt go to Fezz...Hulk has done so much kore to deserve to be there...Bottas cant even outqualify Massa at the moment
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
