RBR dug the hole ... no doubt.
But i say BS to chassis argument. Look at how RBR had an average chassis at the start of the year. They were allowed to develop which they have done and easily one of the best 3 going at the moment.
Argument could be made that they are the best.
Now engines...all but 3 teams are locked into what they
are given/bought. You could argue Williams get the same gear but this year they have been behind in spec and it is absolutely an engine formula. They tried to fix that issue years ago by freezing engines as a variable to within a few percent.
Now thats its a variable let others catch up just as they can from an aero or susp or brake perspective. Freezing it when it is a huge variable is silly as Renault and Honda teams are forced to sit out a season.
Good on Merc for getting it right...theybdeserve their championships....but imagine if other teams were banned from developing a blown diffuser...or an F-Duct etc....
Engine homologation has, is and always will be, shit.
Kimi is also taking a 5th engine this weekend. It's just not newsworthy for him because he's on half the points of his team mate and not in contention for anything.
Vettel is really only racing Rosberg anyway. Hamiltion's 66 point lead is basically insurmountable with 100 points left on the table in the 4 remaining races. He could DNF two of them with Vettel winning both, and still afford to finish 2nd to Vettel in the other two...
That's an awkward way of saying Vettel would have to win all the remaining races and hope Lewis DNFs at least two of them to even have a sniff! It's never going to happen.
Alonso will be running the new Honda PU all weekend too for the first time - only used in a prac session before. So it will be interesting to see if that goes any better than Jenson's old PU. Apparently this new spec engine introduces their direction for next year.
Edited by hrd-hr30
So will the English prat Palmer get his ass handed to him by Pastor? I doubt it but hope so. i like jim a tad more than James Calado which is really saying they are all tools from different shelves!
How guys like Frijns sit on the bench while...ok. Its the weekend and I should relax
Definitely to invested.. haha.
Let's be honest vettel isn't as big of a tool as homo is.
i dunno about that.....
TBH you have to have the sort of attitude they do to be a world champion. You can say what you want about homo but he can bloody drive.
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
