bah, that was just a gentle flop over after bouncing off the tyres. With modern barriers that wouldn't be an issue. Or you could move the wall back. But they'd obviously have more tarmac instead of the gravel trap these days too.
Well, they haven't got an agreement with Renault to supply unbranded engines yet... I imagine Renault would only go ahead with it if they are extremely confident their works PU will be clearly better. Renault engaged Illien at the end of 2014 to help develop their engine. I've read that Renault decided to pursue their own development path rather than use Illien's input...
Have RBR pilfered an ERS guru from another team or something? Otherwise they're probably on a hiding to nothing here.
Edited by hrd-hr30
Building engines probably isn't Renault's problem, it's the associated ERS and "Power Unit" rubbish that teams struggle with.
If the regulations were changed to allow more conventional type engines, fans would enjoy it more and the complexity of design and fabrication would be a lot lower therefore making the units cheaper.
No brainer really.
Edited by Nee-san
Talk is the single cylinder prototype yielded improvements. But as RBR were the ones that paid/introduced Illien they are disputing it is their IP and want to own it. I understand that is largely why Renault are kicking on with their own developments and it seems RBR will use the Renault motor as the basis with the Illien tweaks
Also, the talk is its the atual engine and turbo that is weak with the Renault and the energy recovery majic works well
I wonder if Louise can turn the switch back on next year or whether he will go to sleep now he has 3 x WDCs. Mercedes will have us believe development tweaks have moved the car in Rosbergs favour but surely Louise spending too much time in hotel rooms with C-grade rappers and F grade groupies has more to do with it
Nicole%2BScherzinger%2Bangry%2Bembarrass
I wouldn't be surprised if Hamilton has someone employed to teach him how to act to be liked... The way he answers questions now, initially it's what made me stop hating him as he seemed more humble, but these days it's like he's reading straight from a script..
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
