Actually they have improved the roads now. Kings Hwy (thanks to foreign relationship) is very very good now, I've been told.
Although this beast only runs in the airstrip. Its on E85, which is imported privately. Country's only R35 runs on local 91 + octane booster. Surprisingly runs ok!
Okay back to topic, thread needs more Evo guyss..
http://i1229.photobucket.com/albums/ee463/mick_o1/20130818_132850_zps1324c240.jpg
Heres my 9 stock block FP green turbo,Cosworth M2 cams, toxic fab manifold, Link G4 ecu, spoolin up COP, ohlins coilovers whiteline sway bars, carbing airbox, custom intake and short route intercooler pipework, flex fuel sensor, DBA 4000 T3 rotors QFM A1RMS pads Hel braided lines & probably more that i can't think of lol. When tuned should go around 320kw on E85 & Around 270kw on 98.
  • Like 1
Haha of course of course, evo demolishing corners is standard :P i was curious considering that is a lot of power !
A good all rounder evo you have there.
Judging by the vid and mods done to this evo, id say 11.7ish in your car
  • 4 weeks later...
Nice and stealth Rob :)
Whats the 6262 like on the 4G response wise?
Wasn't too bad at all, lag was noticeable but i had full boost around 4500rpms as long as you stayed in the higher rpm range it was great.. had an issue with my 38mm external gate and stepped it up to a 44mm later on and had no issues... 4G63 motor is my favorite 4cyl definately over the EJ20's and EJ2.5's
  • 3 weeks later...
Developed some shaft play, even though It was freshly reconditioned before it was sold to me, only been on the car for about 6 months :(
Luckily it's still under warranty but in saying that, it's only covered dependant on the cause of failure.
Should see some good results with the 712, very responsive turbo!
I was opting to get that or the red/green. But decided on the red, simply cause I had plans to do a stroker build in the future.
On a 2L, it's not really fun driving on the street, full boost at ~4300ish :down:
I'm selling a precision 6466 with JMF 1.5" runner ceramic coated manifold and turbosmart 45mm pro gate. Good for comfortable 500kw.
Downsizing for response to BW EFR7670, twin scroll, twin gates.
Any predictions for boost threshold on a 2.3 stroker, +1mm intake and exhaust valves and kelford 280s? I know the cams aren't ideal for response but couldn't be bothered changing them.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
