Actually they have improved the roads now. Kings Hwy (thanks to foreign relationship) is very very good now, I've been told.
Although this beast only runs in the airstrip. Its on E85, which is imported privately. Country's only R35 runs on local 91 + octane booster. Surprisingly runs ok!
Okay back to topic, thread needs more Evo guyss..
http://i1229.photobucket.com/albums/ee463/mick_o1/20130818_132850_zps1324c240.jpg
Heres my 9 stock block FP green turbo,Cosworth M2 cams, toxic fab manifold, Link G4 ecu, spoolin up COP, ohlins coilovers whiteline sway bars, carbing airbox, custom intake and short route intercooler pipework, flex fuel sensor, DBA 4000 T3 rotors QFM A1RMS pads Hel braided lines & probably more that i can't think of lol. When tuned should go around 320kw on E85 & Around 270kw on 98.
  • Like 1
Haha of course of course, evo demolishing corners is standard :P i was curious considering that is a lot of power !
A good all rounder evo you have there.
Judging by the vid and mods done to this evo, id say 11.7ish in your car
  • 4 weeks later...
Nice and stealth Rob :)
Whats the 6262 like on the 4G response wise?
Wasn't too bad at all, lag was noticeable but i had full boost around 4500rpms as long as you stayed in the higher rpm range it was great.. had an issue with my 38mm external gate and stepped it up to a 44mm later on and had no issues... 4G63 motor is my favorite 4cyl definately over the EJ20's and EJ2.5's
  • 3 weeks later...
Developed some shaft play, even though It was freshly reconditioned before it was sold to me, only been on the car for about 6 months :(
Luckily it's still under warranty but in saying that, it's only covered dependant on the cause of failure.
Should see some good results with the 712, very responsive turbo!
I was opting to get that or the red/green. But decided on the red, simply cause I had plans to do a stroker build in the future.
On a 2L, it's not really fun driving on the street, full boost at ~4300ish :down:
I'm selling a precision 6466 with JMF 1.5" runner ceramic coated manifold and turbosmart 45mm pro gate. Good for comfortable 500kw.
Downsizing for response to BW EFR7670, twin scroll, twin gates.
Any predictions for boost threshold on a 2.3 stroker, +1mm intake and exhaust valves and kelford 280s? I know the cams aren't ideal for response but couldn't be bothered changing them.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
