Any DOTA players in here? After holding off for ages I have just bitten the bullet and installed it and have played around 20 games so far.
Played a lot of HoN back in the day, and got up to near 2000 PSR, but started to rage too much (much to the GFs dismay) and got rid of it.
Username is CB3 if anyone is up for a game. Have been playing Lich, Lion and Dragon knight in limited pick to get used to the game and characters but I am getting to the stage where I will start branching out...too many noobs :P
https://www.sau.com.au/forums/topic/451205-dota2/
i've been getting into it, but starting out is hard because you get lumped in limited pick or AP games with the new and just plain horrible players.
Have branched out into my old HoN players such as Mirana.
I like to play support/ganker any recommendations for characters?
https://www.sau.com.au/forums/topic/451205-dota2/#findComment-7440521
One of the best ganker is Kunkka, one of the heroes I want to learn.
I usually use Spirit Breaker, he's easy to use. Just grab a BKB and charge in ;).
https://www.sau.com.au/forums/topic/451205-dota2/#findComment-7440969
  • 1 year later...
ok, so The International main event is starting in a few hours.
I couldnt care less about DOTA or valve or teams or whatever. but esports fascinates me in a mind-boggling kind of way. $20mil+ prize pool. over $18mil of that is taken from in-game purchases.
There are paid-entry screenings in each capital city in Aus. including one at Crown in melbourne for the final (kicks off at 2am local time I think), and for some reason I'm tempted to attend. I've watching maybe 20mins of a DOTA stream once before, but I think its just the draw that normal spectator sports have with added weirdness.
https://www.sau.com.au/forums/topic/451205-dota2/#findComment-7764778
  • 1 year later...
  • 1 year later...
  • 6 months later...
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
