Hey this might be silly idea but Im curious, what if you did a comp test , then did the adjustments would the right adjustment raise its compression the highest?
Edited by AngryRB
Hey this might be silly idea, but what if you did a comp test , then did the adjustments would the right adjustment raise its compression the highest?
Its not as simple as that.
Overlap will lose compression when testing like that, but raise the dynamic compression ratio higher in revs and make more power. Cam shafts and timing are crazy technical, mixed with black magic and heaps of guessing and testing to get it optimal.
Also depends what characteristics you are chasing.
A comp test tests part of the dynamic comp ratio but only tells you half the story, simple advancing the intake cam alone will give you a higher psi reading simply becuse it closes the intake valves sooner increasing the compression stroke lenght increasing the volume that gets compressed into the same area and due to the cranking speed used to do the test changes the VE
The best way to test and tune cam timing changes is on the dyno where you can see the slightest changes in a controlled repeatable evironment
  • 6 months later...
Okay so it goes back on the dyno to play with cam timing on Tuesday.
I think I will just start by doing what GTRPSI said as that should give me a good basis to work from.
Any other ideas/feedback appreciated [emoji4]
  • Like 1
Well if bet my left nut it's not electrical. Did absolutely everything myself and tuner could think of but still no avail. Thinking it could be a leaky injector seal or something similar.
Out of rego at the moment anyway so I haven't touched it yet.
Missfire started at 5500rpm and continued from there. Still make 340kw on 17psi with a safe tune to account for missfire only revving to 5500.
  • Like 2
Jez did question it (running standard cams/springs/etc) but we both felt it was electrical in nature and tried to pursue that. Ran out of time in the end but will go back and try and suss it out.
What other ways does valve float manifest itself?
Try running it up at lower boost and another run with more boost early on. If it makes it to say 7000 rpm without the "miss" and then when you give it more boost it happens at say 4800 rpm, good chance it's that.
I've had the same issue on my own car and it turned out to be float. Sounded like a missfire.
With 7psi gate spring it make 295kw on 14psi revving to 7krpm. I then put a 14psi spring in and went back for retune and minimum boost we could run was 17psi and it started missfiring, another thing, it seemed to get worse with heat soak, the more runs back to back the earlier it would start doing it.
Tried 2 known good sets of splitfires, and brand new BCPR7ES starting at .8 and working down to .55
Definitely not an issue with ignition. Started at 14.3V and dropped to 13.8V when miss started.
  • 2 months later...
how will you determine 4degrees on the intake cam?
Do you think the stock cams will do much being adjusted, im thinking the RB30 would love more beefy cams as you have higher comp and a bigger pump..
Edited by AngryRB
By moving it the same amount as the exhaust cam, I have marked the standard intake cam gear so have a reference to work with.
Yes aftermarket cams would make considerable difference I would imagine. But my standard baby neo cams seem to be doing quite well at the moment. Trent from chequered tuning has made over 400kw on standard neo cams so not looking like they will be a restriction.
Plus $700 buys a lot of tyres so the dollar/fun ratio isn't high enough for me to justify spending that much on some wobble sticks. [emoji4]
  • Like 1
  • 6 months later...
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
