Dropped off the bottom end today to the machine shop. Getting hot tank acid wash bored honed tunnel squared to deck crank nitrated oil galleries cleaned grub screws fitted to crank. Crank modified for 25 oil pump ballanced and a few other things done.
I have been looking at the oil restrictor threads on here and from what I can make out I need to block off the rear feed in the block and put a 1.5mm in the front one. Car is mainly for street use with the odd track day. Or would I be better off with 2x 1mm feeds or 2 x 1.25mm?
Edited by lcxu105
Well your call but 2x 1.0mm gives slightly less flow than 1 x 1.5 but has the security of two feeds instead of one (in the hopefully unlikely event that one gets blocked). On the other hand 2 x 1.25 flow a LOT more than one 1.5 (don't forget you can buy them from me unless you have a better source).
  • 5 weeks later...
Well been a while since I've done anything else. Its going to be a long build. Pick up arp head studs tomorrow. I have a new inlet and exhaust gasket now waiting. Machine shop is making slow process but not worried as I told them I don't want it back until about May June. Have been told that the Nistune won't be able to handle the setup as will have to much air flow for the airflow meter. Will have problems with it stalling. Waiting for Matt from Nistune to get back to me. Worst case I'm up for a new ecu. Any suggestions?
Adaptronic.
Whilst Adaptronic or any other aftermarket ECU are perfectly valid suggestions, it is not true that you can't use Nistune because of having too much air flow for the AFM. You can put a Ford Lightning AFM onto it - Nstune can handle it. You can put an R35 GTR AFM's sensor into a 6" pipe and measure 3000HP worth of air if you want to. There's not really any limits from that point of view. The main limit with Nistune is lack of extra functions and sometimes the problems where the stock ECU's self protection behaviours get in the way of tuning more extreme engines. Sometimes there are ways around them, and sometimes there are not. Sometimes the ways around those problems get found before, during or after your build/tune. Sometimes they don't.
I was in the same boat last year. Loved the nistune just the AFM was a little annoying with my intake setup as I am running a 4" pipe. Talk to Matt about a mob over in the U.S that does specialty AFM's. It was what I was going to run as it was perfect for my situation and Matt has already integrated them into nistune.
I have a topic on here about it, search and you shall find.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
