Looking to replace or rebuild r32 gtr gear box.
First of all just jap is selling a brand new r33 gtr gearbox for 2.9k (very tempting!) Which i already know is the better beefy box
Or
Can i rebuild my original box the same if not better for the same price as this r33 box
just asking ppls opinions on what i should do as im still new to the gtr scene.
Hope to hear back from yous, cheers
https://www.sau.com.au/forums/topic/451991-need-help-on-gear-box-decision/
Hi Ben, what's wrong with you current gearbox, and what are your future plans for the car?
They are a very strong box from the factory (not many cars come standard with a box that handles 2-3x factory power) so what you have may not need anything, particularly if it doesn't crunch on quick changes from 4th to 5th
If on the other hand you are building another 500kw time attack car, you will need something a bit more expensive.....
Hey theres nothing concerning with my box atm however there is a continuing howling noise coming from that area it could be the pressure plate or it could be manny things my machanic said cant put his finger on it so itll have to come out to find the problem...
theres no crunching ...ive never launched it so it hasnt been abused.
However ill be recoing the car looking to produce 300kw at the wheels or maybe 350kw if im lucky.
Just want everything done once and done right so i can just drive my car and nothing braking . At the end of the day its a 24 year old car and things need to be re-done or replaced.
Cheers, ben
33 gearboxes have been know to be more prone to breaking then 32 gearboxes, you would also need to change the clutch it self and the slave cylinder (unless yours is a 2/93>)
Have you check the basics like it actually having oil in it?
Also of it only needs a set of bearings it will be cheaper to recondition your gearbox
The stock box will be able to do that provided you don't try and rip the gearstick out of the box every time you change gears.
Like everything to do with cars, a little care goes a long way
There are very few differences between standard 32 and 33 gearboxes, and in any case the 32 stuff has been superseded by Nissan with the 33 series 3 internals; so if you rebuild your box you get 33 series 3 stuff anyway.
A standard box is fine for 350kw assuming you are not abusing it (and it sounds like you aren't). If your current gearbox is noisey (bearings) or crunchy (synchros) you can get it rebuilt for under 2k. But in most cases noisey is the thrust bearing which is external to the box and easily replaced, the second most common noise is the front bearing on the gearbox which can also be replaced without much trouble.
BTW you don't have to change the clutch to use a 33 gearbox, they can be converted back to r32 style (pull clutch) by swapping across the front cover of your current box into a 33 one. I bought a brand new 33 box years ago for the race car and did that conversion to suit 32.
Unless you have money burning a hole in your pocket I wouldn't do anything gearbox wise
If you get to this point the answer is Hollinger. As an aside Hollinger distribute Wavetrac - so how do we convince them to sell us some Wavetrac goodness for GTR's?
Edited by djr81
lol you can say it's name, it's the price that hurts....over 20k....
Plus sequentials are illegal in every racing category in Australia except supercars and Porsche cup.....so it would make an expensive trackday car
Bhaha sshiiit 20k later
And so it begins. Take note of the day you laughed at the prospect of spending $20k to fix a GTR.
Yeah but I just want a Wavetrac diff out of them. Which apparently they dont make from GTR's. See here for the full list of fail.
http://www.wavetrac.net/application.htm
Anything close to fitting the rear?
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
