Off topic but how do i find out what my primary colour is?
I think it's gun metal grey but not sure. don't know the colour code
I need to get my front bumper resprayed so i need to find out exactly what my colour is.
Should I just take it into a paint shop?
Edited by Whoa Black Boaty
engine bay - I'd use the exterior colour with no clear
Paint code is on the build plate - then go search for the Paint Code thread :thumbsup:
Oh WTF - its the first pinned thread in this subject! http://www.sau.com.au/forums/topic/138419-nissan-paint-codes/
Edited by Sinista32
I know my paint code but the list didn't include the color for the inside as I asked. Already checked the pinned thread. Anyone else?
I thought all early models, except white and silver, came matt black in the engine bay.
(My grey 90 model is matt black under the bonnet)
But you have a 94 and by then Nissan was offering more engine bay colour options.
Same colour as exterior but without clear coat is my guess.
On your build plate, next to the paint code, is a letter. This letter denotes the interior colour/trim.
For example, mine is 326 G.
The paint code is crystal white and the interior colour/trim is black.
Or, alternatively, you could just put your VIN through Nissan's FAST for the same information.
  • 1 month later...
