I know it is not much (more reason to scrap as much as I can), but can you transfer my points from the previous account?)
ill look at what I can do about it and let you know
  • 4 weeks later...
With a two man race tonight thing couldn't have been more intense! Was on the edge of my seat the whole time!
Race Results -
11705654_10154099263304386_8400952709208
Season Standings -
10430487_10154099263259386_2755448939928
Join us next month for another Aus track round, will be mixing things up a little and will post here in a day or so to see what everyone thinks :)
lol I didn't even race and got 15 points
I didn't really like that track, ended up playing project cars for a bit after raging at the spec racer random oversteer :P
Edited by UNR33L
  • 4 weeks later...
With the next round coming at Bathurst I'm thinking of adding more cars than just the V8 super cars. What might people like to drive around to mount? perhaps gt3 or maybe coast around in an MX5..?
Let me know what you think :)
I'd love to take the Jetta out, but its about the same playing field as the Solstice or MX5.
Noted, easy to put in. It is a no points round so a bit of fun more than anything :)
Car line up for tomorrow will include -
Both the Ford (FG01) and Holden V8 super cars.
MX5 Cup
Ford Spec Racer
VW Jetta
Unfortunately this is all the cars that iRacing will allow so I can't add any more.
So really this round is just for a bit of fun on the mount. See you on track tomorrow night :)
  • Like 1
  • 4 weeks later...
iRacing is retarded and im ready to delete it off my hard drive. its barely worth $20AUD a year let alone $120aud every year.
is SAU going to switch to Project cars or something similar? anything else?!
I've almost been tempted with rFactor. Can follow almost all of the real SAU Vic motorsport event with available tracks not to mention the cars you can find. Plus it is a once off payment too.
Anyone else think a change next season to something different?
Sorry, I was a bit frustrated last night from trying to do an online race. All 15 iRacing setups for Street Stock were failing tech inspection, even at max ride height it was still "too low"
Anyway, I'd be keen to try rfactor 2
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
