good afternoon all,
im looking to purchase a fairly stock 32gtr from a fellow member interstate and bring it over to SA.
the car is mostly stock with a few bolt on upgrades, Im planning for the hard road as far as getting the vehicle checked out by regency and registered here in adelaide, hopefully its easy and smooth but i dont want to be left uninformed and out of pocket.
i know a few Japanese vehicle workshops specialize in getting vehicle off defects and the likes, i want to contact a reputable shop who know the common fixes and issues to get an idea of additional costs in getting a full roadworthy complete with the upgrades that i know the vehicle has.
who would you recomend?
If it is registered in another state the car doesn't require a full inspection, only Id check.
However they do generally look for non standard items and won't let them through. So prepare for something a little less annoying than full inspection!
yeah Ben im defiantly hoping for a simple id check, i do want to make an effort so i dont get picked on though, plan for the hard way hope for the easy way.
i intend to check for leaks and the likes, obvious stuff (any major obviously i wont be buying)
i want a reputable place to bring certain parts (hopefully with supplied bits??) to stock aswell as a chekover and basic service and health check.
if anything needs replacing i will do it at the same time.
what i expect to need doing:
suspension swapped for stock items (springs only as their stock struts)
exhaust swapped for stock (or quieten down if needed)
remove tint
remove boost controller
pod filters???
braided oil and water lines?
ecu and high flowed stock turbos hopefully wont be an issue as their not an easy pick
Pod filters would be a problem if not mounted correctly, bit for the sake of everything going smooth I would use a stock airbox (airbox nd keep using it)
I have been through a full inspection with a crazy restrictor in my exhaust , so exhaust doesn't have to be stock, just quiet.
Tint and boost controller for sure need to go. Like you said turbos are extremely ulikely to be picked, in which case they won't go looking for a different ecu ideally. Full inspection they check ecu.
Good luck!
i actually agree with the airbox,
if i get to the point of looking at ecu and turbos then im defiantly at the hard road stage. a stage i dont want to get to.
thanks bud
silly things like tint i will just remove, why start an argument, even if you win your going to get but hurt. same with springs, ill just go stock.
Edited by GH05T
  • Like 1
Bought my BNR32 from Melbourne about 5 years ago, took it to Lonsdale for an ID Check
Got pulled up on the tint only and got it removed to pass the inspection. It was fairly stock and the engine bay looked pretty clean.
I got annoyed at the tint as I'd have to put it back on and it made me take two trips instead of one...
Is it correct to assume if the vehicles got a pink slip or RWC that it'll be fine for SA rego? considering other states have seemingly stricter regulations?
For reference, they changed the tinting laws in SA back in 2010, to be more in-line with the rest of the country - you're pretty much good at 35% all 'round now (used to be 70%)
Anyway Vince at Import Compliance Systems helped me get my GTR through. I went in for an ID check for a car from NSW and ended up going back 3 times until I could get it registered.
They kept adding to the list of things to fix up.
  • Like 1
I think custom imports do a bit of this , can even sometimes help with loan parts. Can't remember name of other place, will comment back if I remember. I haven't personally used them or anyone else in this regard though, just going from word of mouth.
  • Like 1
Tint should only be an issue if it's darker than legal anyway.
You can also check your ride-height against:
I'm pretty sure this is still the legal / enforcable ride-heights.
2012 update (latest) here:
https://www.sa.gov.au/__data/assets/pdf_file/0015/15261/Passenger-Car-Track-list-May-2012.pdf
Engine:
Custom made catch can with oil return - Remove, even if legal and returned into intake
INDUCTION
Garrett 2860-7 ball bearing turbos - Fine
Nismo 800x300x120 intercooler sprayed in black - Fine
Fuel system
BOSCH 023 in-tank fuel pump -Fine
GATES bigger fuel hoses - Fine
Nismo 600cc injectors - Fine
Engine management
APEXi power fc with hand controller - remove hand controller, fit a standard ECU cover on the PFC
HKS EVC boost controller - Remove
Blitz turbo timer - Remove
Exhaust
HKS exhaust manifolds - Are they cast?
NISMO 3.5 inch exhaust from dump pipe back - Block it up with steel wool and a baffle
Suspension&brakes
Genuine Bilstein full adjustable coilovers - Remove
NISMO strut brace - Fine
NISMO adjustable arms - Remove
CUSCO brake booster stopper - Might as well remove, its easy and it draws attention
INTERIOR
NISMO seats - Fine
Remove tint if not legal, Clean seat belts with hot water and lubricate, standard-ish wheel, good tyres, check high mount brake light.
Does it have a compliance plate fitted?
Turbos will be fine, as long as they are in the garret housing. If they dont have a reason to check ID tags on turbos then they wont. Does it have braided lines? or nismo/adjustable actuators.
Dont put standard ECU in, put the standard ECU cover on the power fc and remove controller.
Or buy my engine and exhaust gasket kit for R32 and swap over turbos, but the money you pay to swap turbos off then on again, you might as well just give it a shot with the -7.
Edited by JiN_MaN
Yeah I had a handfuls of pages open and I think I just made an assumption in my head that the car you were looking at was the car I had open on the next page. I have no idea how/why I did this, leave me along its been a long day. :domokun:
Post of up mods of the car your looking at. Most stuff will get through an ID check if they have no reason to look.
yeah, hoping they dont but being realistic an r32 gtr they are likley to look.
i want to be in the situation where they see a basically stock tidy car, pop the bonnet for the id check and see a stock tidy engine and move on.
if ti was me and i saw pods, exhaust and aftermarket wheels which need checking i would start looking for more shit.
plus i like the idea of a clean tidy car with minimal mods.
my intentions is to build a mildly modified car as close to if not keeping it legal, stock airboxes which have perfect power applications. suspension which is legal and decent like bilstines, high flowed stock turbos decent no headaches good flowing exhaust ect
  • Like 2
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
