Hello, So ive just brought my very first turbo car (R33 Gtst), im learning fast but I still need some help. so ive brought a dual stage boost-T ive hooked it up and car seems to run sweet, cant really test it till I get a boost gauge tomorrow tho.
Now I know this question has been asked LOTS, but trust me ive posted on forums, and searched internet for ages but got nothing, so why not ask the experts?
Now my question is: Is this hooked up correctly?
https://www.sau.com.au/forums/topic/452410-boost-t-install-help/
I'm guessing it's not hooked up right.
If that T piece shown in the middle of those three bits of hose is just a plain T, and there is no restrictor involved in the line going down to the wastegate actuator, then it will do very little.
A "boost T" is a controlled leak of the boost signal. There is an adjustable valve in the "T" that lets more or less of the boost signal out of the line. There must be a restrictor so that the flow (that ends up leaking out through the "boost T") through the restrictor suffers a pressure drop.
The reason they are called "boost Ts" is that the valve and the restrictor are bundled up into the same body (the T) and they are installed into the boost line as if they were a T piece. The signal source and actuator being on the two connections and the other leg of the T being the hole through which the air is leaked out - hiding somewhere on/in the body of the T. Look at http://www.turbosmart.com.au/wp-content/uploads/2011/10/5483.jpeg to see how a typical one is installed.
Its a dual stage boost T. I understand what you mean about needing a restrictor in the middle but how I've hooked it up seems to be the only way? Maybe I'll just buy a normal boost T and hook that up seems a lot easier.
Edited by AshR33Gtst
OK, well now that we know the actual type of boost controller, 10 seconds spent on Turbosmart's site provides the following instructions
http://www.turbosmartdirect.com/Product-Categories/Manual-Boost-Controllers/Dual-Stage-Boost-Controller-Blue.html#instruction
Click the Instructions link on that page or click the following link direct to the file.
https://system.netsuite.com/core/media/media.nl?id=177080&c=830533&h=946a342eea68c3fc2e82&_xt=.pdf&ck=lmUxAvMCAh_EXjAZ&vid=lmUxAvMCAibEXn3O&cktime=131827&addrcountry=AU&gc=clear
Edited by GTSBoy
That's hookd up right, it's a boost "T" which means it bleeds boost pressure out of the wastegate line via the T though an electric valve, this one does so by two different size valves depending on which one is switched on
A long time ago when turbos started becoming popular a mate put a single cam CA18 turbo in a canary yellow 1200 coupe, to lift the boost level he put a T in the wastegate line then ran a meter of hose off the side of the T then cut 1 inch at a time till he got the desired boost level, this worked a treat
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
