Hey guys
Thought It was finally time to create a build thread for my R33 gtst as its coming along nicely and not to far off getting it out on the track for the sau championships. Hopefully for round 2 29th March.
I brought the car back in July 2014 as a unregersted stocker for $4000 with the intention on just entering a few track days here and there but that quickly has changed and now the aim is to build it up for the WTAC to compete in the open class.
Since then I've been buying parts for it most weeks and slowly getting it closer to how I want it.
First was a set of BC ER coilovers 9kg front and 7kg rear.
post-84279-1420806451604_thumb.jpgpost-84279-14208064688793_thumb.jpgpost-84279-14208064892183_thumb.jpgpost-84279-142080650985_thumb.jpg
Also went in were whiteline front and rear sway bars.
Next was a set of R33 GTR wheel which I brought off another sau member.
Which I decided to bring them back to life and painted them black.
Also brought some semi slicks to wrap them in. Brought some nitto nt01.
Over the next few weeks I brought a few more go fast bits. Bpp Billet fuel rail, splitfire coilpacks, apexi power fc with hand controller, tomei fuel pressure regulator, walbro 450ltr fuel pump, Bosch 1000cc injectors, bride low max seats and a pair of D2 330mm 8pot brakes with race pads.
post-84279-14208080548781_thumb.jpgpost-84279-14208080656826_thumb.jpgpost-84279-14208080770801_thumb.jpgpost-84279-14208080884917_thumb.jpgpost-84279-14208080994456_thumb.jpgpost-84279-1420808115474_thumb.jpg
Next the car was sent off to mcqueen motorsport for a full cage. Had a few hiccups there but eventually got the work done after a few months sitting at the shop. Decided on full weld in 6 point cage($2500). Also had to removed the sunroof to give me a little bit more headroom. Now left with a gapping hole in my roof which should be getting fixed in the coming weeks.
post-84279-14208082666846_thumb.jpgpost-84279-1420808280969_thumb.jpgpost-84279-14208082961318_thumb.jpg
Got it home and the gave it a few Coates of matte black paint.
post-84279-14208083432498_thumb.jpgpost-84279-14208083545996_thumb.jpgpost-84279-14208083656818_thumb.jpgpost-84279-14208083760969_thumb.jpg
Got to spend some time on the car over my holidays and installed the D2 brakes.
Removed all the sound deadening and gave the interior a fresh coat o gloss white paint to clean the inside up a bit.
https://www.sau.com.au/forums/topic/452512-wilsons-r33-gts-t-time-attack-build/
Next on the to do list is find a panel shop to patch up the hole in the roof and respray the front bar. So if anyone on here knows of a good panel shop please let know.
After that is sorted the car will be sent off to racepace to get a tune with all the parts installed.
Still need to buy either garrett or Hypergear turbo which I have on my daily. Top mount 6boost manifold, plazmaman plenum.
Looks great so far. Whens the aero coming to play?
Tao does the SS2 Alpha with FNT, makes 350kw+. Though on your standard engine...not sure how far the internals go in a track day arrangement.
Most of the guys struggled to hold oil pressure over 350kw.
Before giving the front bar a tidy up, perhaps figure out what cooler mounting and ducting is needed, and whether you'll even retain the stock bar? Richo's build thread has a lot of good info/pics.
What sort of power will you chase out of this thing? I've wondered how a Hypergear TDO6SL2-20.5G would perform for a track application like this. Mightn't go much past the 300kW mark but it should be responsive and reliable unit.
Aero shouldn't be to far off. Need to get that front bar lower and design up a front splitter. Either looking at getting a rear wing similar to yours or a decent size carbon fibre GT wing. But they are a bit pricey. Still pretty new to all the aero stuff tho.
Yeh that's the exact turbo I've been looking at from Hypergear. I've got the SS2 on my daily and have been pretty happy with it.
Power figure I'm roughly looking at chasing atm is 300-350rwks on e85. But will most likely rebuild the engine this year to chase over the 400rwkw. Considering doing a 25/30 setup to achieve that.
  • 4 weeks later...
New engine time!!
Forged rb25/30 getting built as we speak.
Fully prepped block
Argo rods
Arais Pistons
King turbo bearings
Arp studs
Balanced and ground crank
Full reco head
Welded vct
Can't wait to drop this is in nd hit the track. Will post up more pics as the build comes along.
Edited by BLK-51N
Also decided that since I'm spending all my hard earned money on this car that it was time to insure it with Shannon's. Got a pretty good deal for an agreed value on $20,000 only $500pa. Good to have that peace of mind. Don't no what I'd do if something happened to it uninsured.
Hey well the aim is to have it fully ready with the 25/30 in it by mid year hopefully. But should have the car out on the track at sandown on the 4th of April.
Mainly just gunna enter in the sau championships and the WTAC.
Yeh for sure come in nd I'll show you around the car.
Just hanging out bad to get this ready nd out on the track. See how much power I can push out of this forged rb25/30.
Edited by BLK-51N
  • Like 1
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
