I've got an idea. set anti-lag launch end RPM at 8000 and get a mate to film from outside the car. You know, for science
have already done this at 7000 haha I feel that the neighbours were less than impressed.
you want peak cylinder pressure at around 12 degrees atdc,any more or any less and you lose torque, you therefor need to ignite the mix so it burns at a rate that gives peak pressure at that angle, as revs go up, the piston moves faster so mix needs to be lit earlyer or peak pressure will occur after the desired angle, and waste power, yet you dont want to advance to much as the other side puts stupid amounts of strain on the motor and wastes energy to.
however as more load is placed on the motor, more heat is in the chamber so mix burns faster, so timing needs to decrease to keep peak pressure at the right angle, or else your firing to early and can cause damage from to much strain.
this is on a motor that isnt limited by knock,
most rb25 with big turbos and huge boost will be knock limited at some point, so wont actually be able to be at 12 degrees atdc with peak cylinder pressure as the burn is to unstable and starts pinging so in these cases peak pressure ends up being later atdc to keep things working without damage
how do you measure this?
knock ears and a dyno,
increase timing in a cell while holding steady state on the dyno and watch the torque fiqure, it will plateau and then drop, at the start of this plateau is where you want your timing to be, any more or any less and your wasting power and arnt helping the motor at all,
if when advancing the timing it starts to ping before it plateaus, thats how you know the engine is knock limited, and timing needs to be put back to stop the pinging
slight changes in engine setups, and even just slight tollerance differences between motors, is what could make one map work perfect for one persons motor, and make another persons motor need a tow truck, so be careful when playing with ignition timing without the correct tools
interesting, thanks for the detailed response. Eventually I will have the eflex sensor tuned to run 98/e85 mix.
Everyone's quoting timing numbers but not saying what rpm its at.
Top right corner of my e85 timing map is 26 degrees (7500rpm) from Toshi and that was conservative. I don't think he liked putting 20 psi through the stock rb25
hmmmmm.. as a tuner tuning on both road and dyno its not advisable to take timing maps from other cars... different turbo ,mods, compensation maps bla bla make a huge difference..
i made 415HP @20 psi with 22* on a 6262 on 91 oct
i also made 499 hp @21 psi with 27* on a borgwarner 8375 using the same 91oct with waiter injection.which would bring it up to 97-103 oct....
but whose to say if my compensation map is pulling 5* in the back ground . or if my finial timing is 27* but my intake temp is super low...
quick answer though...with everything working cool and proper fuel you should be able to go 18-20* at 20psi ...
it your street tuning you would feel the difference...go up 20* make a pull and make a pull at 17* if both feels like there pulling the same leave it at 17 once knock is not present.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
