It's a perfect description of me. If you were in Brisbane, I would think you were talking about me.
lol
You guys piss me off
I weigh 40kg less and can just hang off the ring
speaking of knees. saw the surgeon yesterday afternoon.
announcing my immediate retirement from basketball and squats.
have worn away the cartilage in my left knee, so it's bone on bone.
going on the public waiting list to get it op'd, but he says if I take it easy from know, ie no basketball and other high impact sports, I should make it to 60 before I need a full knee replacement. sucks
back on topic. I am finding that a whole bottle of jaeger and redbull the night before did not help with my workout this morning. scratch that of the list.
  • 1 year later...
Good to see this thread is still ticking along. Some things i've learned that are hopefully true;
You should have simple (high GI) carbs <2 hours after workout. Glycogen, which is a form of glucose stored in the muscle for energy, is used when you work out and you want to restore it post workout, by spiking your insulin via eating simple carbs. This is done most effectively during that 2 hour window. You also need some protein at the same time. I've seen recommendations from 2:1 to 5:1, carb to protein. (mlr mentioned the carb+protein goodness earlier).
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
