I've recently converted my skyline to united e85.
Had the car tuned and the result was 410hp at 18psi.
The tuner had stated that he couldn't put any more boost in because of valve float.
So I had some performance springs valve springs installed.
Had the car retuned and the result was 437hp at 23/22psi
The tuner had stated that the car still had valve float above this level.
He asked what springs installed and commented that they're not up to the task and had seen many customers have similar problems.
Raising the boost would not effect the power curve and estimated power figure not reached.
I'm disappointed with the situation and would like to know what you guys think?
Should I change springs again?
Should I change dyno operator?
Is this a below average outcome for my setup?
Is this valve floating?
Mods include but not limited too:
Garrett Gt3076r t3 .70 comp .82ar ex wg
3.5 inch exhaust
100mm thick cooler 3in piping
China ffp
Standard throttle body
Walbro 460
Id1000
Mls head gasket
Wolf 3d v5
  • Like 1
https://www.sau.com.au/forums/topic/453567-valve-float-next-step/
I would have thought that >300 rwkW on a 3076 on E85 was getting close to the full potential of the turbo.
I would wait for the advice of others with more experience with those turbos before taking anything I said about it to heart though.
The other thing that occurs to me, now that you have posted up those dyno charts, is that there doesn't seem to be any giveaway of valve float showing up in the curves. Usually when they start to float you at least see some sort of upset in the curve. I'd be asking your tuner what signs or behaviours he is using to tell him that it's floating.
It's a rb25 series 1
I agree that the curve doesn't show a typical valve float situation.
The tuner stated that as he tried adding boost in the higher rpm range the curve stayed the same as you can see in the graph.
He said swapping the springs for supertech would fix it and show a big increase in power.
I'm just skeptical having already spent a bit of coin.
Edited by BEN 0
I was of the impression that the GT series tend to, well.. die in the ass after about 22-23PSI on a RB
In other words moar boost = no moar power.
This was the impression I got when reading about the GT3076 when compared to GTX3076, in that the GTX series continue making power under more boost after the GT series has stopped making gains.
There is a good chance that the valve seats have been cut and all the japanese branded valve springs don't have enough tension if the seats have been cut. i have seen this issue arise on 3 different RB engines (2x26s and a 25) all 3 upgraded to super tech to fix the issue and have shown great results
Higher lift would make it worse, one car was bad enough he couldn't get it to rev cleanly, it was almost as if it was hitting a rev limiter at random spots in the rev range. Changed springs and pulled over 450kw at the wheels
That's very interesting Brett, thanks for you input.
If you can remember, how big were the gains on the setups you seen?
Would changing to higher lift camshafts help with the spring situation?
How big of gains regarding what exactly?
As Brett said, shoving higher lift bump sticks in there won't be doing any favours unless you get a decent spring in there.
Was just trying to gauge the difference in performance by changing the springs.
Just need to weigh up the options with my goals. Would like to reach 500hp.
Replace springs and retune
Replace springs and cams and retune
Replace springs and turbo to GTX
I see, if there is a better option feel free to let me know.
The tuner recommended super tech, from doing a search it seems they only make a single spring to suit hydraulic rb25
part no. SPRK-2081/rb25
Ferrea do a dual spring for hydraulic with slightly better specs
part no. S10112-24
Would either of this be the right choice?
What camshaft have you got in there? I highly doubt you'll need a duel spring!
If you keep it at say 20% throttle, will it rev out to 7000 rpm without it doing it's thing?
If you give it more boost, does it do it's "thing" earlier?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
