You can say the statement is shit all you like, but if you actually have a decent engine builder that checks the seat pressure you will find you can't get enough seat pressure without the creating a coil bind situation because they are made to soft from factory
I agree but that's because you chose the wrong spring it's not japan's fault that the spring don't work it's yours.
your statement still makes no sense
Edited by mr skidz
we have all used different brand and model of springs and they all have the same issue, it's ok we've made the mistakes and are happy to pass on the information. If you still choose to buy them and then end up paying twice, I really don't care cause I've learnt from my mistakes and won't be making them again
Well since you're tomei springs were to soft what are they rated at and what were they measured at, tell me what the difference was because I have some here that I haven't used yet and I plan on checking them before installing them if you are correct then I will bow to your comment
Might have been 60 was 3 years ago, but you're welcome to ask Joey or piggaz about their experience with Japanese valve springs. Make sure you ask Joey tho cause his is definitely a story you'll want to hear
lol is that what you had before?
if so what rate springs did you settle for piggaz ?
That's what I installed, yes. I don't know how it got past me but when the stupid thing was carrying on like a two bob tart on the dyno I went and saw the bloke that put the engine together. That's what the seat pressures were. We
ripped them out and put in a camtech single spring and Ti retainer package (which fit SO much better then the previous stuff), put it back on the dyno and issue was gone.
19 psi, 6500 rpm it would float at. Go half throttle it would go to 8000, give it more boost and it would fluff around at 5000 rpm.
Best bit was the camtech package was so much cheaper than the jap stuff, fit as it should and did the job.
Never tested what the seat pressures were as the swap was done in the car. But it went onto hold 30 psi no problems.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
