  • Replies 71
Sydneykid ( to find out if he REALLY does own a w/shop )and to also pick his brains
Charley cos she sounds like a nutter female( I love nutter females who drive imports)
Cheers
ken
I have a few...
SST Steve: to score a hit of his dyno potion
SydneyKid: so I can hook him up to one of those machines that sucks all that information out of ya brain, and then hopefully translate it into something I can understand.
R34GTT-R: (Adrian) so I can shout him some KFC, a couple of bottles of JD, then I'll poke his eyes out.
that's it for now...
I like meeting everyone. Met more great people today. SAU actually does have a lower Dickhead to normal person ratio than real life :D
Specifically though:
Sydneykid so I can thank him for setting me on a new career path in race engineering
Steve in SA
Jay up in Qld
Nizmo in perth to see if she really is that cute, but I'm hooked anyway cos she has 2 imports.
Mzdefectd cos i keep coming up with old threads where she is fought over by the guys. Must be a pretty special lady. Wanna count her defects too, no really.
No one really. So far everyone I have met from SAU have been a real disappointment.
Was a bit dillusioned about this whole SAU thing after meeting Snowy, but yeah you get the occasional wierdo...
hehe, met Duncan... and Dino... they reminded me of the odd couple. Met Carlo... he's my hero lmao.
Would like to meet Sydneykid, and sit there with skylinegeoff and him and troy (ylwgtr2) and make this Skyline of extraordinary power and grace.
Wouldn't mind meeting Shell... but during the night time, coz she's a lil cranky during the day.
Also on list of people to meet... Jimbo, Rezz, Tosh, Sock, Tay, Skyzzer and Porgie.
Speaking of meeting up with people, I gotta meet up with PranK soon so I can give him his boot trim which I've been promising him since he got his GTR lol
We'll you [and anyone else] can meet me this Sunday at the Dyno Day :rofl:
Horus - already met him... wish i never did :jk: .. hes a psycho lol .. jk - dont mess with him or else your fcuked! hes a fcuken PIMP i tell yah !!!
would like to "brainnap" sydneykids brain and then dump his body somewhere and get a machine and suck out all the info he knows !!!
also would like to meet that vl turbo uleh leb guy or whatever he is called! - he cracks me up
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
