Sold my R34 GTT so i have a heap of new parts i never got around to fitting. Send me a message if interested in the parts your chasing. I only have one of everything you see. Mfd has tv button and full harness not cut.
Will post prices shortly.
Exedy heavy duty clutch kit with flywheel.
Genuine z32 bosh air flow meter
Sard 550cc injectors
Nismo short shifter
Tomei poncams type B. 260' inlet and exhaust duration
Tomei fuel pressure regulator
Nismo shift knob.
Nismo high flow fuel pump
Sard fuel rail
R34gtt gauge pillar pod 52mm
Sard fuel rail
Autometer wide band air fuel ratio and boost gauges.
Apexi version 2 ECU and hand controller
6 boost dump pipe and high flow cat with 50mm waste gate adapter
TURBOSMART 2 stage boost controller
All of these parts are new and genuine and i paid big $$ for them but since selling the car they are no longer needed.
Mobile 0419654081 Steve
Edited by stev076vl
https://www.sau.com.au/forums/topic/454032-new-r34-gtt-parts-for-sale/
Where are you located and how much for the clutch?
I'll call dibs if you're in Vic and we can come to an agreeable price :)
Edited by Cowboy1600
  • 3 weeks later...
Location near brisbane QLD.
power fc $900
Cams sold
Shifter and knob sold
Full heavy duty clutch kit with flywheel $900
Nismo fuel pump $350
Mfd and harness $1050 will be shipped to buyer in Germany if not sold locally.AU
550 cc sard injectors $550
Sard fuel rail $250
Fuel pressure reg $80
Gauge pillar pod $120
Z32 afm $250
Dump pipe and racing hi flow cat $300
Will suit t3 t4 turbo
All of these parts came from japan
And are new still in boxes. Dump pipe is used.
  • 4 weeks later...
  • 4 weeks later...
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
