I am sorting out a 12 sec R33 gtst setup. I am running a GCG stage 1 highflow @16-18psi, power fc etc,etc. My question is how many people have tried aftermarket cams, such as HKS or Tomei and the like. What sort of perfromance gains did they net?? and are they believed to be necessary running the above boost?? What setups are people usung to put down consistant 12 sec 1/4 miles.
https://www.sau.com.au/forums/topic/45409-12-sec-14s-and-aftermarket-cams/
I'm guessing sydneykid is gonna jump in cause he has had previous experience with the GCG highflow and I believe he has a r34 with the same highflow running 11.7 on street legal tyres.
PS I dont think the cams are necessary but we'll wait for someone with better knowledge to jump in.
I'm dying to see what SK has to say here, as I want my R34 to go 11.7 on street tyres....
With cams.
A question.
Would there be a lot of gain from using Tomei Poncams on standard turbo.... OR should I up the turbo first?
If you're running those mods you should NOT need to change cams at all to achieve your goal. It will obviously help though.
Good tyres. Seriously.
Adrian
My old gtst had a HKS 264/ 9mm lift exhaust cam added at the time of a stock spec rebuild. Running the factory turbo and intercooler.
The gains occured right through the power band to the tune of about 20hp. The midrange is very healthy.
You have a larger turbo and stand to gain an even better average power improvement. Like some have said it might not be required to get a 12 but, to get there easy a set of cams is the go.
If it loses traction just throw more power at it, eventually you will get there :D
you should need cams at all.
i ran 12.9 with 225 tyres... and about 200rwkw.
stock head etc, mild tune ECU
with a GCG hi-flow you'd be over my old power for sure.
Tyres are your answer here as others have said
rev210: So you used the standard inlet cam , with the hks exhaust? did you have to get cam gears and adjust timming? interesting tell me more. After the cost of cam gears if used wouldnt there be more point in getting a set of tomie pon cams that work with the factory gears.
Does anyone know the lift of the 256 tomie pon set?
Yeah, what Adrian said. It's easier to measure the gain (if any) of a mod if they are done one at a time, if the cams don't do anything for you (I personally don't think you need them for mid/low 12's) rip 'em out and sell them.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
