im looking for a genuine oem style
plug-in injector for std rb26 rail & harness plug and no adapter plugs i want straight plug in.
needs to be 700cc or slightly more with twin hole?
does anything exist?
hks do a 800cc twin hole but not sure it fits oem rail, can anyone confirm?
https://www.sau.com.au/forums/topic/454235-help-rb26-injector-upgrade-question/
No adaptor plug? You want the stealth look?
The Xspurt 2000's are bosch plug, possibly more have it, I would have to ask the wholesaler. You will require step down adapters to 11mm, or for the injector to be machined down to 11mm which I can have done for a little extra.
You would have to ditch the injector resistor pack for any modern high impedance top feed, just remember the 26 injector is a 30 year old design so anything based on that (ie same body design like Sard) will be crap. Newer won't have 2 holes either, possibly 4,6 or only one, but that makes fark all difference at the high gas speeds inside the runners.
hey scotty, thanks for the reply in regards to adaptor plug i don't want to use one just a straight drop in original plug design is what i'm after two holes or more obviously i would prefer i have used sard in the past and have found them easy to use and install never had a problem so i was hoping to find something of that calibre i know the amount of holes won't make much difference at high gas speeds but they do make a difference at lower gas speeds. If you don't mind me asking what is wrong with the design from sard just out of curiosity?
you dont ship to the US >_< best price i seen for 2000cc , also need adapters for stock rail.
I will ship anywhere, the website just ins't setup well atm due to not having any time to load all the data, and international shipping calculator add-ons are very hit and miss. PM me if you like. Our crap dollar would help you with pricing nicely.
Personally I wouldn't spit on Sards, I had a set here we pretty much gave away. Modern Bosch injectors crap all over them for economy and spray pattern, and any tuner will tell you it saves plenty of time on the dyno.
Anything bigger than Nismo will be a drilled injector which will likely fail on you at the worst time.
So much this. Having gone from Sard 800's to a modern 2000, I can tell you the 2000 idles much nicer and drives so much better than those old wrecks. To say "nope, nothing that doesn't drop in" for a sake of a plug change is crazy.
wow you wouldn't spit on them?
big call they're basically a nismo 600 with a larger orifice?
take like 7minutes to fit and no cutting factory harness yes there old as design but so is my car so there era correct :) and never had a problem tuning them but i would prefer at least 2hole design and only 100 each delivered.
good value I reckon
Edited by mr skidz
There is no cutting of the factory harness with the 2000's either, many modern injectors still use the same Bosch plug, and the ones that run US plugs have a simple adapter these days.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
