im looking for a genuine oem style
plug-in injector for std rb26 rail & harness plug and no adapter plugs i want straight plug in.
needs to be 700cc or slightly more with twin hole?
does anything exist?
hks do a 800cc twin hole but not sure it fits oem rail, can anyone confirm?
https://www.sau.com.au/forums/topic/454235-help-rb26-injector-upgrade-question/
No adaptor plug? You want the stealth look?
The Xspurt 2000's are bosch plug, possibly more have it, I would have to ask the wholesaler. You will require step down adapters to 11mm, or for the injector to be machined down to 11mm which I can have done for a little extra.
You would have to ditch the injector resistor pack for any modern high impedance top feed, just remember the 26 injector is a 30 year old design so anything based on that (ie same body design like Sard) will be crap. Newer won't have 2 holes either, possibly 4,6 or only one, but that makes fark all difference at the high gas speeds inside the runners.
hey scotty, thanks for the reply in regards to adaptor plug i don't want to use one just a straight drop in original plug design is what i'm after two holes or more obviously i would prefer i have used sard in the past and have found them easy to use and install never had a problem so i was hoping to find something of that calibre i know the amount of holes won't make much difference at high gas speeds but they do make a difference at lower gas speeds. If you don't mind me asking what is wrong with the design from sard just out of curiosity?
you dont ship to the US >_< best price i seen for 2000cc , also need adapters for stock rail.
I will ship anywhere, the website just ins't setup well atm due to not having any time to load all the data, and international shipping calculator add-ons are very hit and miss. PM me if you like. Our crap dollar would help you with pricing nicely.
Personally I wouldn't spit on Sards, I had a set here we pretty much gave away. Modern Bosch injectors crap all over them for economy and spray pattern, and any tuner will tell you it saves plenty of time on the dyno.
Anything bigger than Nismo will be a drilled injector which will likely fail on you at the worst time.
So much this. Having gone from Sard 800's to a modern 2000, I can tell you the 2000 idles much nicer and drives so much better than those old wrecks. To say "nope, nothing that doesn't drop in" for a sake of a plug change is crazy.
wow you wouldn't spit on them?
big call they're basically a nismo 600 with a larger orifice?
take like 7minutes to fit and no cutting factory harness yes there old as design but so is my car so there era correct :) and never had a problem tuning them but i would prefer at least 2hole design and only 100 each delivered.
good value I reckon
Edited by mr skidz
There is no cutting of the factory harness with the 2000's either, many modern injectors still use the same Bosch plug, and the ones that run US plugs have a simple adapter these days.
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
