im looking for a genuine oem style
plug-in injector for std rb26 rail & harness plug and no adapter plugs i want straight plug in.
needs to be 700cc or slightly more with twin hole?
does anything exist?
hks do a 800cc twin hole but not sure it fits oem rail, can anyone confirm?
https://www.sau.com.au/forums/topic/454235-help-rb26-injector-upgrade-question/
No adaptor plug? You want the stealth look?
The Xspurt 2000's are bosch plug, possibly more have it, I would have to ask the wholesaler. You will require step down adapters to 11mm, or for the injector to be machined down to 11mm which I can have done for a little extra.
You would have to ditch the injector resistor pack for any modern high impedance top feed, just remember the 26 injector is a 30 year old design so anything based on that (ie same body design like Sard) will be crap. Newer won't have 2 holes either, possibly 4,6 or only one, but that makes fark all difference at the high gas speeds inside the runners.
hey scotty, thanks for the reply in regards to adaptor plug i don't want to use one just a straight drop in original plug design is what i'm after two holes or more obviously i would prefer i have used sard in the past and have found them easy to use and install never had a problem so i was hoping to find something of that calibre i know the amount of holes won't make much difference at high gas speeds but they do make a difference at lower gas speeds. If you don't mind me asking what is wrong with the design from sard just out of curiosity?
you dont ship to the US >_< best price i seen for 2000cc , also need adapters for stock rail.
I will ship anywhere, the website just ins't setup well atm due to not having any time to load all the data, and international shipping calculator add-ons are very hit and miss. PM me if you like. Our crap dollar would help you with pricing nicely.
Personally I wouldn't spit on Sards, I had a set here we pretty much gave away. Modern Bosch injectors crap all over them for economy and spray pattern, and any tuner will tell you it saves plenty of time on the dyno.
Anything bigger than Nismo will be a drilled injector which will likely fail on you at the worst time.
So much this. Having gone from Sard 800's to a modern 2000, I can tell you the 2000 idles much nicer and drives so much better than those old wrecks. To say "nope, nothing that doesn't drop in" for a sake of a plug change is crazy.
wow you wouldn't spit on them?
big call they're basically a nismo 600 with a larger orifice?
take like 7minutes to fit and no cutting factory harness yes there old as design but so is my car so there era correct :) and never had a problem tuning them but i would prefer at least 2hole design and only 100 each delivered.
good value I reckon
Edited by mr skidz
There is no cutting of the factory harness with the 2000's either, many modern injectors still use the same Bosch plug, and the ones that run US plugs have a simple adapter these days.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
