Hey guys,
Coming to sydney in a few weeks for a fri sat and sunday before i go overseas.
Im staying in the heart of circular quays.
What is the night life fri n sat nights like there?
Where would you recommend?
any help would be great
cheers
If you're staying in Circular Quay the closest area with a decent night life would probably be the Rocks but that is mainly pubs and restaurants. Wandering a bit further to darling harbour will get you to cargo bar/king st wharf and a bit younger crowd.
Kings Cross is a lot quieter than it used to be since the lock-out laws came in but there are still plenty of places open.
Thanks mate.... ill google the cargo bar.... yer looking for a bit younger crowd...
but after a decent bar / music with a younger crowd nothing major
Edited by Adz2332
If you're staying in circular key be careful of the lockout, all pubs and clubs won't let you in the door after 1:30am in certain areas of kings cross and CBD. I'd google it and you should get the picture with the lockout zones in it. If not give me a shout and I'll try and find it.
There's an awesome German bar/restaurant called Lowenbrau in the rocks which is 2 minutes from circular quay, it's great for a big lunch feed and some quality steins.
If you're into craft beers try a place called Harts, they brew their own beer and use some other local breweries and they're amazing beers.
As far as clubs and what not I'd try places like Bar 100, again in the rocks but is more night club like
Hope some of that helps :)
hahah fair point....
For one would like a nice var, younger crowd not over in the 40s etc...
Then not so much a night club but a bar with music again young crowd preferred....
Ive been to darling harbour once before, and all i can remember of it was 50 somethings in very bar i went to
the glenmores a good place to visit on a friday if you get in later arvo, although can get crowded with the afterwork crowd.
Can also venture on to the Argyle from there afterwards. Was my old friday night special when I used to work around there
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
