Air Bag Suspension C34 Stag
Grimi
 Share
Just wondering if anyone has put an air bag suispension in a c34 stagea?
Thanks to my Takeros front bumper i cant go any coilovers (currently sitting 105mm from ground @ a 380 ride height with any coilovers dropping ride height to 365 at heighest point bringing front bar to just 90mm from the road) and stock replacement is non existant in brisbane apparently so it has to be custom springs ect which is gonna cost me around 1453 (fitted so not too bad) but wouldnt mind being able to raise it to get into my driveway rather than having it sitting on the road waiting to be hit again.
Any info would be great, dont mind having to travel a bit to speak with someone with some knowledge about options. Cheers
Somebody makes kits for just that job - not replacement suspension but just a booster for getting into parking buildings etc. I'll have a look but last saw it a few years ago.
Had a quick Google and BC actually make one (not the one I saw before but...) called Aircup
There's a few air suspension kits for r33 and 34 skylines, I presume one of those would fit. I'm in the stages of bagging a Pmn35 Stagea and there was no kits that I could get my hands on, luckily 350z has the same setup as a m35
  • 3 weeks later...
did a fair bit of hunting around for these, saldly i couldnt find anyone with a direct fit kit (make it easier and cheaper so i can install myself), cheapest quote i got was $4500 installed... with parts being roughly $3000 and they wouldnt sell just parts so for the time being thats just gonna have to wait i guess...
  • Like 1
You won't find a specific kit in australia, maybe in Japan though. As I said above, it'll be easier for you to find a car that shares the same suspension and look for a kit to suit.
$4500 installed isn't that bad considering my M35 install is going to cost $4400 just in parts. What air managment system and struts are you looking at using?
i couldnt tell you to be honest, they did tell me but i cant remember, was going to be tripple front and rear with a removeable controller hidden in the center colsole, tank behind the rear bar and all the pistons ect in the spare wheel well.
Though Ive decided to go back to stock height shocks+springs with swaybars front and rear, need to keep my car legal at the moment and according to QLD Transport if i bag the stag it wont be legal on QLD roads and because of this my insuance company wont accept any claim if anything does happen... which sux.. gonna leave it for a year or two till im ready to do some more then reassess.. would still love to put bags in though.
yeah sadly from what ive dicovered it would require changes to the law.... if it didnt come out with airbag as a standard feature then it cannot be legally done anymore... which sux
  • 11 months later...
What happened with this? Anyone find where to buy air bag suspension kits for c34 s2 Stagea?
Doubt you'll find any c34 specific kits from well known brands (airrex, airrunners). As long as 33 or 34 skyline struts fit in the c34 there's plenty of kits out there
 Share
    • Neostead, I'm looking to have a custom surround done that also has a slot for a fog light. Would you be willing to create a 3d model I can buy or create and ship me the part or even provide/sell the current model for me to modify? Cheers
    • Did some maintenance on the MX5, did the engine oil and filter which was uneventful, then I drained the coolant to put in the new reservoir and a thermostat, reservoir took 5 minutes  The thermostat, well that took.........3 bloody hours, what a job, the issue was the 3 bolts holding it on, one was easy, 2 were hidden and required a few 1/4 drive extensions, 1 more than I had, and a 1/4 swivel, which I also didn't have, and a good amount of playing contortionist  Getting the 2 unseen bolts back on was a time consuming nervous nightmare, as I couldn't see where they went there was alot of stabbing and hoping for the best, trying to line up a 8 mm bolt straight, which you cannot actually see or get a hand in there, with a 1/4 swivel in the mix was a nightmare Anyways, it's done now, all burped out, and run up to temp a few times, happily no leaks thank Jebus After the thermostat fiasco I decided I need a few mental health days away from tools before doing the rest of the servicing on it As for the Dunnydoore, it had the aircon regassed and it has a clean bill of health, thinking about taking it out on Monday for a cruise down the coast to look at some houses if weather permits
    • In other important race car news, instead of fixing the race car I changed the crank seals on the chainsaw, because wood burner Some damn tight (and lock tighted) m6 head bolts Who knew plastic crank cases were a thing! Quick tip, don't trust the youtube videos that say you can pull the old seals out with the head on in a husky 440e...not true, their crank seal tucks in behind the cover both sides. I'm not sure I'm a psychopath, but these things are damn loud....hope I can put all the bits back in the right place    Happily, it is now back to turning fallen trees into a combination of firewood logs and wood chips....just need a clear day to get into it properly
    • I've got 60L of e85 in there at the moment
    • Don't forget to make sure the tank is full to the brim before you try to replace the fuel pump too, that is an essential step.
