I took a trip to the states and saw some guys using Cadillac CTS big brake calipers and evo rotors, and from what they say it cost the 500 dollars or less for everything up front. Almost all of them I see is on s14 silvia or s14 240sx has any one tried these setups on the r32 gtrs as it would be a great up grade for very minimal cost. Im thinking about doing it. I know I have done it tge next way around. I have put r32 gtr brakes on a s14 silvia. And only the metal gaurds needs to be straighten out for the bigger rotors everything else fits. Ive even did it from r34 GTT to s13 and only the bolt holes needs to be open up on the front knuckles. (Caliper mounting area) plus the metal plate being flattened out.
Anyone seen this before?????
https://www.sau.com.au/forums/topic/454655-cadillac-cts-brake-upgrade/
I havent seen it, but am interested.
From what I can tell they are the same calipers as used on our Holden commodore ss redline. The front calipers and rotors can be purchased brand new just over 1000, but the rotors are wrong stud pattern for Nissan. Haven't seen price for calipers in their own but are probably reasonable.
At enjukuracing ask for Andrew he has the whole setup for 550 dollars. Look at the follow photos of the part numbers. Its dead cheap. Even worth the effort. I sceen shot our conversation. The part numbers are there. They look bad as☆ on the cars and are very very big he also have me a quote at 1100 if I wanted a 2 peace rotor, but at the 550 its worth the effort.
From what he is saying only the brake lines would be in question. The z32 300zx should work on a r32 gtr though. Seems like some strict laws in Australia. Hmmm:angry: damn governments.
  • Like 1
What size rotor are they quoting?
These need a 355mm rotor at minimum, guys are selling them with a 350mm rotor and it's causing issues...at least that is what a reputable brake company is sydney told me.
Although If I can fit 355mm rotors under my wheels, I'll be all over this
We are getting a lot of VE Commodore owners using these calipers with larger rotors that they purchase from us here in Melbourne.
They buy the calipers from the states dirt cheap (so they tell me) and they bolt straight onto their VE's with bigger discs.
Appartently much information on some Aussie GM forums, its a very popular conversion ATM.
LOL...oops
1977480_1467919253491254_875719207386226
10374072_1458557351094111_33752211508925
YAY..someone doing it right
10469417_1481141688835677_70998644059160
Looks a reasonable upgrade. Neat brackets too. Does anyone actually know the piston sizes of the calipers and whether they have different sized pistons?
Also, anyone gotr pics of the pad, rotor edge? The caliper doesnt appear to saddle the rotor all that tightly?!?!
Yeah lots of VE/VF owners doing this upgrade.
It's reasonably cheap, not $550 cheap though once you get to AUD.
Hmm. Well I guess your right there. For once im on the lucky side. Lol
Those are the 4 pots, 2012 model moved to 6 pots. Ctsvbrakeswap (link above) will hopefully have their production bracket available soon to suit these using z34 14" rotors.
A member on one of the american zed forums made a small quantity of brackets also but these required a fair bit of modification to fit, I'll probably give the above brackets a go once released
Edit: piston sizes are different & from what I can find are 30, 34, 38
Edited by lidz
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
