they say to use the nismo 350z rotors which is around that size.. IDK it took them 3 months to reply to me on FB, maybe someone will try it out and take one for the team.
Whilst the fitment is more or less the same, don't make the mistake of thinking that 32GTR and 33GTST brakes are the same. GTRs were 32mm thick.
